MAC Underdrive Pulley Help Please - TCCoA Forums
post #1 of 4 (permalink) Old 10-26-2002, 04:42 PM Thread Starter
hey guys on the stock crank pulley do i need to take out the big one in the middle or just the 4 outside ones thanks
lx2sc is offline
post #2 of 4 (permalink) Old 10-26-2002, 06:48 PM
JUST the 4 smaller ones, 13MM head I believe...........
rancherlee is offline
post #3 of 4 (permalink) Old 10-29-2002, 07:10 PM
CatBird Creator
Send a message via AIM to ChromeTip
hey, i just bought the set of u/d pullies too. i just wanted to ask before i even attempt this, where are you coming from to get at the bolts? above or below the car? also, can I do it with a racthet set? I dont have an impact wrench, but i want this pulley on there. i have the belt too, everythings ready to go on. thanks
Kyle
~Legendary Catbird Creator~
Now owner of 1994 Thunderbird LX...where do i start?
ChromeTip is offline
post #4 of 4 (permalink) Old 10-29-2002, 09:36 PM
I went in from below the car... you'll need a a small extension maybe and a breaker bar unless you have an impact wrench.. just loosen the four outer bolts.. then push on the tensioner, then take off the belt, then take off the four bolts and pulley, then put on the new pulley and put the four bolts back w/ loctite... then put the new belt on...
sanbei120 is offline
