How many o2 sensors does a 3.8 have???? - TCCoA Forums
post #1 of 14 (permalink) Old 10-28-2002, 06:07 AM Thread Starter
CamellionCat's Avatar
Send a message via AIM to CamellionCat
do our 3.8's have only one o2 sensor on the right catalytic converter?????
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #2 of 14 (permalink) Old 10-28-2002, 10:28 AM
Marvin M.
Mine has one before and after the converter, the converter behind the exhaust manifolds. So if my math is correct I have 4 (four) sensors!
post #3 of 14 (permalink) Old 10-28-2002, 10:42 AM Thread Starter
4 sensors ????
where are the other 3??? i know theirs one on the right converter but where are the others located if you can help me out with this.
thanks
Marvin M.
Back in the game!!!
post #4 of 14 (permalink) Old 10-28-2002, 10:48 AM
Marvin,
Just like I posted above, one before and one after. Look at the manifold and follow the pipe. You'll have to probably get under the car to see the sensors behind the converter, mine are near the tranny pan area.
post #5 of 14 (permalink) Old 10-28-2002, 11:06 AM
ONLY the 96-97's have 4 O2 sensors, its a requirement of OBDII so the ECC can "watch" the effecentcy of the converters (BIG BROTHER type of thing)
rancherlee is offline
post #6 of 14 (permalink) Old 10-28-2002, 11:13 AM
So he should have 2 then correct, one for each bank?
post #7 of 14 (permalink) Old 10-28-2002, 11:17 AM Thread Starter
Ive only seen one by the converter.
there might be another one but i dont know where i have a 95 3.8. I want to clean them, and thats why im asking.
thanks
Marvin M.
Back in the game!!!
post #8 of 14 (permalink) Old 10-29-2002, 05:04 AM
well when i looked under my car the first time at school i was amazed to find out that i have two cats instead of one plus i've been told by some teacher's (who mostly know about ford ) that there's an oxygen sensor in front of a "cat" (or was it behind well i'll check the next time i look under the hood.
cougar 3.8 is offline
post #9 of 14 (permalink) Old 10-30-2002, 12:59 PM
Marvin
I believe (or so I was told there are 2 o2 sensors......Call a Ford dealer and find out....They will know by just looking it up on their computer
BeirutsFinest
BeirutsFinest is offline
post #10 of 14 (permalink) Old 10-30-2002, 01:46 PM
o2 sensor
they are mounted in the rear portion of the left and right exhaust manifold
post #11 of 14 (permalink) Old 10-31-2002, 08:24 AM
90 3.8 lx
I have one O2 sensor in the bottom of the passenger side header
MFD 38 LX is offline
post #12 of 14 (permalink) Old 10-31-2002, 08:27 AM Thread Starter
Kewl do you guys know if........
a lean running o2sensor can make a difference with the reading of the temp gauge???????? Also if the o2sensor is running lean will a throw a code???? or will my check engine light come on???????
Marvin M.
Back in the game!!!
post #13 of 14 (permalink) Old 10-31-2002, 02:30 PM
Pedal Faster
Josh_Keady's Avatar
That's a lot of question marks...
Well, let's define some thing really quick, first. A sensor won't "run" lean, it will indicate a rich or lean situation... it senses oxygen. So a lot of oxygen in the exhaust stream indicates lean, very little oxygen indicates a rich situation.
An excessive lean situation will cause the car to run warmer, but the car should compensate for that by making the mixture richer until the O2 sensor gives it an appropriate value.
If an O2 sensor gets too rich or too lean a reading and the computer can't compensate, it will throw a code, and as far as I know, your check engine light will come on. Doesn't mean your O2 sensors are sending back the correct data though...
Josh Keady
Josh_Keady is offline
post #14 of 14 (permalink) Old 12-16-2002, 08:30 AM
Good luck on trying to get the one out on the passenger's side. Ford conveniently locates it 2" from the firewall. It took me an hour plus a lot of heating with a torch to get it free, as it was seized in place on the manifold. The driver's side isn't too bad, at least there's a little more room to work with.
teebyrd92 is offline
