o2 sensors stuck! - TCCoA Forums
post #1 of 3 (permalink) Old 08-17-2005, 12:23 PM Thread Starter
o2 sensors stuck!
oh man, the o2 sensors in my car are giving me big trouble. They dont wanna come out, I've used PB Blaster to try to loosen them, didnt work, just made the engine compartment smell, tried heatng them up, that didnt work either. What do I do?
DSBirdman89 is offline
post #2 of 3 (permalink) Old 08-17-2005, 12:27 PM
Did you let the PB Blaster set overnight? On things that are really stuck, PB Blaster may take a few doses to work it's way into all the nooks and crannies.
Just my .02 and yeah, O2's can be tight!!
69 F100 LWB w/460 Engine
post #3 of 3 (permalink) Old 08-17-2005, 12:53 PM
I had to change those on my Mark VIII after I bought it used. They hadn't been changed in ages. I'd start on it, get frustrated, and quit for the day. I didn't get them loose till two days after I started tugging on them.
Just keep at it. Drive it for a while to get things hot, then cool it off with a spray of PB Blaster. Let it soak few minutes, then get to work on it again. You'll do it.
Remember to put anti-seize compound on your new sensors' threads.
Oh yeah; try not to put them on too tight.
1992 Mercury Cougar: Donated to Kars4Kids
1993 Lincoln Mark VIII: J-Modded (300hp with no lower 1-2 spring and no 2-3 spring) 2001 Mustang GT transmission; SC Rear Swaybar; SCT Tune by Torrie at Fast Parts Network; B&M 24,000 GVW transmission cooler; '99 Cobra water pump; Polyurethane differential bushings; Solid Rubber Motor Mounts; 1.5" Lowered Coil Conversion Kit from Strutmasters; HID headlights; Crimestopper brand Remote Start
Alpine CDA-9830 head unit; Infinity Kappa 572.5cf speakers; Planet Audio P300.4s amplifier; Resonant Engineering SX12 subwoofer; US Amps XT-2000D amplifier
Mr. 92 is offline
