engine problems? - TCCoA Forums
post #1 of 6 (permalink) Old 08-17-2005, 02:01 PM Thread Starter
engine problems?
i'm not a pro at determining whats wrong with the engine but last night i was driving home from work and evertime i would take off when the light turned green it felt like i was going to lose the engine and when i made it back closer to home the thermomastat rised up realy fast from c to h and the light came on saying check gagues so i parked it and opened the hood and the engine didn't feel hot at all so i looked around and noticed that the fuel injector had some fluid ozzing out of it and it was realy hot over it,also it had a weird smell to it. the radiator was full of antifreeze and the engine oil was full to i just think it was time for something to go but i can't determine it . the car has 113,000 miles on it and just wondering if anyone else had this problemand what it could be and how much it would be to get repaired.
1993birdofprey is offline
post #2 of 6 (permalink) Old 08-17-2005, 02:07 PM
PCD
Confirmed V6 Nut
Any smoke from the tail pipes? Any OIL in your anti-freeze? The symptoms are classic head gasket failure. Know anyone close by that has lots of experience with the Ford 3.8?
PCD is offline
post #3 of 6 (permalink) Old 08-17-2005, 04:28 PM Thread Starter
there is no smoke coming from the tail pipes and no oil in the antifreeze it just overheats and right over where the fuel injector is it gets realy hot and under the car in the same spot the injector is it's leaking fluid all over the ground and i haven't even started the car all day
post #4 of 6 (permalink) Old 08-17-2005, 10:32 PM
PCD
Confirmed V6 Nut
I've heard of hydrolocked pistons. I wonder if this happened. It almost sounds like you'll be tearing down this engine to find the cause and fix it.
PCD is offline
post #5 of 6 (permalink) Old 08-23-2005, 02:11 AM
Joseph Rice's Avatar
Send a message via AIM to Joseph Rice Send a message via MSN to Joseph Rice Send a message via Yahoo to Joseph Rice Send a message via Skype™ to Joseph Rice
How about the Thermostat? I heard if it goes up really fast for no reason at all time to replace the Thermostat
Joseph Rice is offline
post #6 of 6 (permalink) Old 08-23-2005, 10:16 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
sounds more like a leaky fuel injector o-ring. I'd replace the o-ring and your thermostat just to be on the safe side. Doesnt sound like a headgasket to me. Sounds nowhere near a hydrolock. Hydrolock would involve the engine not even running, it wouldnt even turn over.
-Thomas
Thomas is offline
