im having a prob with my idle - TCCoA Forums
post #1 of 7 (permalink) Old 08-30-2005, 10:24 AM Thread Starter
Exclamation im having a prob with my idle
i have a 94 cougar 3.8 and at idle the car drops down to around 550 rpms and the entire car starts radling. when i turn my sterring wheel at idle holding the break the car makes a large rumbling sound and shakes more. it is probably a sensor problem anybody know which one or if its something else???
medicalmike is offline
post #2 of 7 (permalink) Old 08-30-2005, 10:49 AM
PCD
Confirmed V6 Nut
Your Idle Air Controller may be going bad. If that valve doesn't work properly, you don't get enough air to idle properly. It is an easy replace, just remember to get the right gasket with it.
I'd also check out your power steering pump. Is the PS fluid black?
PCD is offline
post #3 of 7 (permalink) Old 08-30-2005, 10:54 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
when you turn the steering wheel it puts a lot of drag on the motor, so having the idle drop while turning the wheel is normal. The only reason it's making the engine shake is because your idle is lower than it should be already. I would also lean towards the Idle Air Control (IAC) being bad. You can try unplugging it while the car is at idle and seeing if the idle gets better or worse. If it gets better or doesnt change then it's bad.
-Thomas
Thomas is offline
post #4 of 7 (permalink) Old 10-10-2005, 01:56 PM Thread Starter
thanks guys that fixed it
post #5 of 7 (permalink) Old 10-10-2005, 02:29 PM
The Stevinator's Avatar
does the IAC throw a CEL?
The Stevinator is offline
post #6 of 7 (permalink) Old 10-11-2005, 09:55 PM
MN1293-232's Avatar
There are codes that it may set though the probability is pretty slim. The only reason I say this is because I have never seen these cars throw a code for that, though that doesent mean much either.
MN1293-232 is offline
post #7 of 7 (permalink) Old 10-16-2005, 01:23 AM
can someone tell me where this is located at on a 91?
CincyT-Bird is offline
