Need a little help. - TCCoA Forums
post #1 of 7 (permalink) Old 08-30-2005, 10:09 PM Thread Starter
Unhappy Need a little help.
Need a little help I have a 94 XR7 with a 3.8, ok here's the problem i'am getting a code 157 which i understand is a mas sensor. I have pulled the mas out and cleaned it no broken wires all is good there. So why i'am i still getting a code? Can you check it to see if it works? If so how do you do that? Any pictures oftesting a mas? Or diagram on it. Any help would be great.
Dartanion is offline
post #2 of 7 (permalink) Old 09-01-2005, 02:47 PM
Drnaline's Avatar
I don't know of a test for them. I would say to order a new one and swope it. It's solid state so there is really nothing to test. You could call ford and talk to a tech for any procedure they may have?
Democracy is 2 wolves and a lamb voting on dinner. Liberty is a well armed lamb contesting the vote.
Drnaline is offline
post #3 of 7 (permalink) Old 09-01-2005, 07:58 PM
doug's Avatar
Just checking, but after you cleaned the sensor did you reset the computer?
Current vehicles:
2002 Black Lincoln LX, 1997 Black F-150 LXT 4x4 w/8' bed - 4.2L, 1995 Red & Silver 40th Anniversary Edition Thunderbird 4.6L, 1994 Black Thunderbird LX 4.6L, 1994 Red Thunderbird LX 4.6L, 1994 Silver Thunderbird - carbed 460ci w/C6 (In Progress), 1994 Black Super Coupe - 5 Speed Manual, 1994 Blue Super Coupe - 5 Speed Manual, 1975 Black Trans Am - 455ci w/4 speed, 1973 Black Opel GT 1.9L w/4 speed & AC!!!, 1969 Black Olds 442 455ci w/4 speed manual
doug is offline
post #4 of 7 (permalink) Old 09-01-2005, 08:01 PM
Unplug the battery for ten minutes or remove the ECM fuse and crank the engine a few times then try it. Any codes you had should be cleared.
Blue LS is offline
post #5 of 7 (permalink) Old 09-02-2005, 09:55 AM Thread Starter
need a little help
Yes I did, reset the computer. And the code keeps coming back.
post #6 of 7 (permalink) Old 09-02-2005, 11:17 AM
girdnerg's Avatar
Just a suggestion, but I would post in the IL chapter and see if someone close has a MAS you can borrow and test with.
Rob
girdnerg is offline
post #7 of 7 (permalink) Old 09-02-2005, 11:19 AM Thread Starter
Need a little help
Hey Rob did'ntthink of that. But I will get on it . Thanks
