AWOL Temp Gauge - TCCoA Forums
post #1 of 4 (permalink) Old 08-31-2005, 11:25 AM Thread Starter
Resident redneck
redneckcougarguy's Avatar
Send a message via AIM to redneckcougarguy Send a message via MSN to redneckcougarguy
AWOL Temp Gauge
my temp gauge has started wigging out on me, as in rising almost all the way to the H, then falling to below the M in norm, just to go back up again and fall again. its kinda acting like a tach does because it rises when im on the gas and levels when i quit accelerating, and falls when i brake. any clues????
-Steven
Project Rust Prevention: 1990 Buick Regal, Toilet Capacity engine, new trim paint, 57K miles
redneckcougarguy is offline
post #2 of 4 (permalink) Old 08-31-2005, 04:01 PM
Well, it could either be an electric problem or a physical one. The physical one would be air bubbles in the coolant. If you check the sticky thread about refilling coolant atop this forum, that should fix the problem. I think there's also a remote chance that you could have a HG leak (which makes air bubbles).
The electrics involve the temp. sending unit (at the front of the lower intake manifold), the wiring from that to the dash, and the gauge itself. One of the components could be bad, or the wiring may have an intermittent short. You could try turning the key to "on" but leaving the engine off and wiggling the wiring to see if you can replicate the problem. You can test the sender with a multimeter, but it won't necessarily pick up an intermittent problem. I hope you can find it.
Steve
S_Mazza is offline
post #3 of 4 (permalink) Old 09-01-2005, 02:41 PM
Drnaline's Avatar
Sounds like a wire pinched or something. Ground issue?
Democracy is 2 wolves and a lamb voting on dinner. Liberty is a well armed lamb contesting the vote.
Drnaline is offline
post #4 of 4 (permalink) Old 10-10-2005, 03:34 PM
having the same promblem just got a sending unit need the weather to get better to change it I will let you know when that happens
1994cougarlady is offline
