mpg - TCCoA Forums
post #1 of 13 (permalink) Old 11-02-2002, 12:29 PM Thread Starter
mpg
96 xr7 v6 48,000 miles
mpg used to be 31 mpg on the highway. has recently dropped to 26.
car has been maintained to mfg. severe maintaince schedule. car is all stock.
any ideas?
laminarflow is offline
post #2 of 13 (permalink) Old 11-02-2002, 04:26 PM
Cougar Pilot
BlackCat94's Avatar
Oxygen sensors? Although you barely have the engine broken in!
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #3 of 13 (permalink) Old 11-12-2002, 08:08 PM
i would kill to get 31mpg. i am lucky to pull down 23 on a good tank of 92
Xpert311 is offline
post #4 of 13 (permalink) Old 11-12-2002, 08:27 PM
BlownMerc's Avatar
Send a message via AIM to BlownMerc
Highway: 24.5mpg
City: 14.5-15mpg
2000 Camaro Z28 auto
SLP Airbox Lid
PaceSetter LT's
Custom Y pipe
3800 Vigilante Stall
Cam Motion 224/228 .585/.585 114
NX 100 wet
HP Tuners
BlownMerc is offline
post #5 of 13 (permalink) Old 11-12-2002, 09:56 PM
mileage
on the highway with my old engine, with the cruise set to 85mph with two people and a trunkload of stuff, i got aroung 28-29mpg......this number really surprised me.
I haven't had the chance to test to see what the new engine gets, but it seems like aroung town it goes through a tank quicker. Must be the fact i can rev it without worring about the knock in the old engine.(Bad rod bearing)
red92V-6 is offline
post #6 of 13 (permalink) Old 11-12-2002, 10:19 PM
city- ~21 mpg (abotu 400 to a tank)
highway- ~ 30-32 mpg (about 600 to a tank, doing 80)
glowing escape is offline
post #7 of 13 (permalink) Old 11-13-2002, 08:05 AM
jturmel's Avatar
How do you get almost 400 a tank while getting 21 mpg? You must run that to the last ounce.
1991 Sport 5.0
RIP 1991-2006
jturmel is offline
post #8 of 13 (permalink) Old 11-13-2002, 08:49 AM
I'm getting 29.5 with my 4.6L
I'm probably going to jinx myself but my 94 4.6L gets the following:
I just returned from two trips and closely verified my mileage and speedometer (new white gauges so I wanted to check everything)
29.5 mpg if I drive 71 mph (cruise control, no racing, and 100% interstate) (speed limit 65 mph (I hate KY and OH! And does OH have enough state troopers!!)
25.5 mpg if I drive 77 mph (again, cruise control, no racing, and 100% interstate) (speed limit 70 mph)
21.5 around town with some racing
4.6L, 3.08, non-posi, modified exhaust, no silencer, 4 new O2’s, new MAF, etc.
And 218K miles… maybe the engine is so loose, it doesn’t have a lot of drag and I get good gas mileage
69 F100 LWB w/460 Engine
post #9 of 13 (permalink) Old 11-13-2002, 02:39 PM
well.. i do.. but i also took my usual mile to a tank and used a calculator and divided it by tank size.
post #10 of 13 (permalink) Old 11-26-2002, 11:42 AM
Gas Mileage
I would never run a tank to totally empty. It makes the fuel pump work harder than it should have to, and any crap that is in the bottom of the tank will surely clog the sock on the pump and the fuel filter. Best bet is to never let it get any lower than 1/8 of a tank.
teebyrd92 is offline
post #11 of 13 (permalink) Old 11-26-2002, 02:28 PM
well.. sometimes the wallet doesn't permit me to put gas in right away like that. so i have to run it down a lot. i do need a new fuel filter tho, thats partially the reason why, that and this one has about 80,000 miles on it, i believe the filter was only changed once in its lifetime. -greg
post #12 of 13 (permalink) Old 11-27-2002, 08:55 AM
Tim Groth's Avatar
Send a message via AIM to Tim Groth Send a message via Yahoo to Tim Groth
I don't think you have much to worry about with the change in MPG. I've noticed that in cooler weather my mileage drops a bit because it runs better and wants more gas, plus I know she's quicker in the cold so I gun it all the time. From reading the other posts I have to agree that you're getting great mileage even with the change.
I wouldn't sweat it but do keep an eye on it for it could be the start of a bigger problem/
Current Collection
1994 Thunderbird SC - Auto
1994 Thunderbird SC - 5spd
1995 Thunderbird SC - Auto
1997 LX - Auto - Parts Car
Tim Groth is offline
post #13 of 13 (permalink) Old 11-30-2002, 03:47 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
also running it on empty oftenly can mean fuel pump replacement because a fuel pump is fuel cooled and if it's only running on fumes then that means no cooling.
-Thomas
Thomas is offline
