Over 75K Miles Motor Oil - TCCoA Forums
post #1 of 5 (permalink) Old 09-04-2005, 09:02 PM Thread Starter
does this stuff really make a difference?? my cougar has 104,407 miles, should i be usin this motor oil?? whats the difference between this and normal oil?
itsnitro is offline
post #2 of 5 (permalink) Old 09-04-2005, 09:04 PM
Who is John Galt?
I used it for one cycle, but it just didn't seem to help out like they said. If you just keep the oil and filter changed regualrly, you shouldn't need it.
"Won't work, can't be done"
cougar_guy04 is offline
post #3 of 5 (permalink) Old 09-04-2005, 11:40 PM
I have 160k on my 89, and I use regular 5w30 and 10w30 Pennzoil. I leak oil from the rear main seal, but the car is about a pint low after 3,000/4,000 miles, so I don't want to deal with it except I can't park in the driveway.
If you use a lot of oil, get smoke after the car is warm and you gun it, then maybe, it mainly helps with valve seals, maybe with gaskets and other seals too. I didn't replace the valve seals when I did the head gasket, and it doesn't smoke at all except after my wife babies it for 600 or 700 miles and I start driving it again, but that isn't oil.
Bangster is offline
post #4 of 5 (permalink) Old 09-05-2005, 09:20 AM
Thumbs up
I have always use regular Castrol oil 5w30 (Winter & Spring) & 10W-30(Summer & Fall). My engine last all the way up to 262,000 miles (60% freeway & 40% city miles) with out any trouble.
KVR Cross-Drilled Rotors
K&N Air Filter
Removed Air Intake Silencer
Original transmission now @ 320,000
JC89 is offline
post #5 of 5 (permalink) Old 09-05-2005, 11:17 AM Thread Starter
good stuff.. just as i thought... i didnt think it was something that great. ill just stick to my normal stuff.... besides my g/f drives the car good.. not fast take off or anything.
itsnitro is offline
