Help Please - TCCoA Forums
post #1 of 8 (permalink) Old 09-12-2005, 02:08 PM Thread Starter
Exclamation Help Please
Every time I start my Cougar, the engine immediately revs to 3500 rpms.
When I disconnected the aii inlet from the throttle body, the rpms drop, but the idle is rough! I assume this is caused by the fact the maf is not in the air stream
all vacuum lines apear to be ok. The check engine light does not come on unles the air inlet is removed. Any suggestions?
mobbclicc is offline
post #2 of 8 (permalink) Old 09-13-2005, 03:37 AM
Resident redneck
redneckcougarguy's Avatar
Send a message via AIM to redneckcougarguy Send a message via MSN to redneckcougarguy
look up by the throttlebody and look at the cables connected to it. one of them is connected via a grommet and is lower than the other two, take a look at the grommet, chances are its busted, letting that lower cable get stuck and sending the revs up to 3500
-Steven
Project Rust Prevention: 1990 Buick Regal, Toilet Capacity engine, new trim paint, 57K miles
redneckcougarguy is offline
post #3 of 8 (permalink) Old 09-13-2005, 10:45 AM
redneckcougarguy, the cable that you're speaking of is the TV cable, which he wouldn't have on his 94 Cougar (89-93's have the TV cable for the AOD transmission).
mobbclicc, it's very likely that you're problem is the IAC (idle air control) solenoid. It's located on the top of the throttle body on your car. Try unplugging the electrical connector to it. If rpm's don't drop (the car shouldn't run with the IAC unplugged), you have a bad IAC.
It's a pretty common problem on the 3.8's.
-Rod
post #4 of 8 (permalink) Old 09-13-2005, 01:01 PM
The IAC probably is the problem, but take it off, there is an accordian looking piece inside, if it is cracked/broken the RPMS will be higher than they should.
Blue LS is offline
post #5 of 8 (permalink) Old 09-13-2005, 04:08 PM
MN1293-232's Avatar
AS they all said check that IAC. I have had this problem. Revs went to 3 bills. Most likely the culprit.
MN1293-232 is offline
post #6 of 8 (permalink) Old 09-14-2005, 02:54 AM
Resident redneck
-Rod
yeah i feel like an *** now.
-Steven
post #7 of 8 (permalink) Old 09-25-2005, 03:44 PM Thread Starter
Replaced the IAC and TPS....still no change....now what?
post #8 of 8 (permalink) Old 09-25-2005, 10:48 PM
Possibly the MAF?
Just a wild thought and not likely, but is anything hittinh the throttle when the air inlet is attached?
Blue LS is offline
