REAR END WOES: Rear end covered in fluid, gasket? - TCCoA Forums
post #1 of 10 (permalink) Old 09-14-2005, 11:51 PM Thread Starter
1997 Thunderbird LX, 3.8L
I was changing the oil in my Tbird tonight, on a lift at a buddy's shop. I happened to look at the rear end, and it was covered in rear diff fluid
It looks like theres these two traction control sensors, one on each side of the diff. The one nearest the exhaust seems to be where the fluid is coming from, it doesnt seem to be coming from the main gasket. Is there a gasket on this little thing? Its the metal block thing that comes out to like a large gear, and where it mounts to the diff is where the fluid seems to be coming from. Also, I need to make a trip to Illinois next week (~300 miles). How bad is the little gasket on this guy to change?
jeffQ is offline
post #2 of 10 (permalink) Old 09-15-2005, 06:58 AM
miller1995's Avatar
Those sensors do not go into the diff the just mount there to look at the exciter rings on the inside of the halfshafts. My guess is you have a bad oil seal where the half shaft goes into the diff on that side. I had one go bad on my last diff and had oil all over on that side becouse the half shaft slings it around I think. I do not think they are too bad to replace but I have only installed them, never removed them because I had another diff rebuilt for me with 3.55's and just did the swap instead
-Miller
SOLDWhite '03 Crown Vic P71
SOLD2006 Mazdaspeed6
SOLD1998 Escort ZX2
RIP My Black 95 LX 4.6
miller1995 is offline
post #3 of 10 (permalink) Old 09-15-2005, 07:01 AM
Do you by any chance have a photo? I'm not that up on the 97's, but I thought the only things mounted to the differential were the ABS sensors (which I thought were also used by the Traction Control. I don’t think those bolt holes go all the way in, just blind, threaded holes), and the vent tube.
So there is something that goes "into" the differential besides the pinion, half shafts, and vent tube?
Are you talking about the half shafts? They have what looks like a gear (which is the toner ring for the ABS/TC). There is a seal (not gasket) where they go into the differential and the seal is a wear item and can leak. The seal is cheap... getting the half-shafts out can be a little time consuming depending on how you want to do it.
But definitely something that can be replaced in a driveway on jack stands.
69 F100 LWB w/460 Engine
post #4 of 10 (permalink) Old 09-15-2005, 07:49 AM
392Bird's Avatar
Get some engine Gunk, and clean it good, then see where it comes from after a short drive.
Here is a shot of my rear end. If it is leaking from one of the sides, it is a out put seal leaking.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #5 of 10 (permalink) Old 09-15-2005, 07:50 AM
JustinH's Avatar
the seal on the diff cover would be black silcon, not really a gasket.
JustinH is offline
post #6 of 10 (permalink) Old 09-15-2005, 08:02 PM
MN1293-232's Avatar
yeah for sure check that side oil seals. I have seen many of these go bad on these cars. Heck I have to replace mine also soon.....
MN1293-232 is offline
post #7 of 10 (permalink) Old 09-15-2005, 08:48 PM Thread Starter
jeffQ is offline
post #8 of 10 (permalink) Old 09-15-2005, 11:02 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
How did you get yours red? he told me they only came in black. did you have yours redone?
Thomas is offline
post #9 of 10 (permalink) Old 09-16-2005, 01:44 AM
wilson502's Avatar
pinion seal might be leakin.
2007 White Ford Focus SE ZX3 Hatchback (The new driver)
1997 Alpine Green 4.6L Bird (SOLD!)
Mods:
Removed Air silencer, Clear Corners, Silverstar headlights and corner lights, Moroso Bluemax Spiral Core wires, Custom 3" Magnaflow exhaust with 2.5" Y-Pipe, 300-450 HP J-mod Kit by dirtyd0g , Hayden 30k GVWR Trans Cooler, Sport Front Suspension, 03-04 Cobra Rear Shocks, PBR Front Brake Swap, Xcal 2 by Lonnie @ Blueovalchips.com, 22C plugs, 180F T-stat, 02GT MAF/Airbox with K&N Drop in, Griffin Radiator, Cobra Water Pump
wilson502 is offline
post #10 of 10 (permalink) Old 09-16-2005, 05:44 AM
392Bird's Avatar
I got mine direct from Billetflow before Rick started carrying them. Billetflow is the one that makes them for the T-Bird and Cobra. You are better off getting it from Rick, since there is a slight difference in them, and the ones that Rick gets are T-Bird specific for proper mounting at the rear mount.
392Bird is offline
