Question about newer engines in 91 T-bird - TCCoA Forums
post #1 of 5 (permalink) Old 09-27-2005, 09:33 PM Thread Starter
I've gone through hell trying to find a good engine for my T-bird (91 3.8 auto). SOmeone posted in other threads that a newer engines would work.
Can someone explain what I need to use to get a 96+ block in a 91 T-bird. Basically I had really bad heads (started to melt) and felt the block was bad so wanted to get a new engine block and heads.
All I need is a block, internals, and heads (no conversions please). I have everything else that I could switch over from my motor ie alternator, PS pump,, brackets, manifolds, intakes, TB, etc. What years and from what cars would work for this?
THANKS
CincyT-Bird is offline
post #2 of 5 (permalink) Old 09-28-2005, 05:41 AM
Any RWD car, up to 98.
post #3 of 5 (permalink) Old 09-28-2005, 09:28 AM
PCD
Confirmed V6 Nut
Joe, I think the cincy t-bird is looking for a more detailed answer. As far as I know, a 96 block will bolt in, but I believe the 96 has DIS ignition whereas the 91 has a distributor. I'm not sure if the 96 can be retrofitted for a distributor or how much cincy has to change. I'm sure the 91 computer would have to be changed out for the DIS.
PCD is offline
post #4 of 5 (permalink) Old 09-28-2005, 10:10 AM
The Stevinator's Avatar
if your looking for a block with all internals check NAPA they sell remanufactured blocks
The Stevinator is offline
post #5 of 5 (permalink) Old 09-28-2005, 10:19 AM
figure out what you need for the splitport 3.8 from a 99+ mustang. 190HP
NiteFire is offline
