Start Up - TCCoA Forums
post #1 of 11 (permalink) Old 10-05-2005, 08:20 AM Thread Starter
Resident Line Creator
th3subtl3on3's Avatar
Start Up
I read about this once before, awhile ago, but can't remember the name of the part for the life of me. So, I'm going to ask.
On cool mornings, when I turn the key to start the car, it starts amost instantly. Now once the engine has warmed up to normal temperature, or even when the temperature outside is warm, the engine cranks a couple times before it finally starts.
What is the cause to this?
-Brian
th3subtl3on3 is offline
post #2 of 11 (permalink) Old 10-06-2005, 08:31 AM Thread Starter
Ttt
-Brian
post #3 of 11 (permalink) Old 10-06-2005, 11:51 AM
The Stevinator's Avatar
starter cylinoid. just replace it. its not that expensive. its the first sign its going out.
The Stevinator is offline
post #4 of 11 (permalink) Old 10-06-2005, 12:00 PM Thread Starter
I guess I should stick with a motorcraft starter? I found them on rockauto.com for 58 bucks not including shipping. They alos have bosch and some other brands too.
-Brian
post #5 of 11 (permalink) Old 10-06-2005, 12:06 PM
make sure you get the cylinoid ( i know im mis-spellng that ). but yeah motorcraft is pretty good, but anyone that is made for your car will work.
post #6 of 11 (permalink) Old 10-06-2005, 12:06 PM
oh yeah. the cylinoid will either be on your firewall by the passengerside fender, or on the starter itself.
post #7 of 11 (permalink) Old 10-06-2005, 01:25 PM
Litning's Avatar
Solenoid
Litning is offline
post #8 of 11 (permalink) Old 10-06-2005, 01:44 PM
thanks litning...im such a horrible speller
post #9 of 11 (permalink) Old 10-06-2005, 11:37 PM
For your 89 3.8 the solenoid is on drivers side fender well, just between your battery and fuse box. They are like 8 bucks at autozone. The starter looks like it has one on it but that is not it.
EDIT: OOPS I thought you had a t-bird. I have no idea where your solenoid is. LOL.
CincyT-Bird is offline
post #10 of 11 (permalink) Old 10-08-2005, 11:49 PM
That's not the solenoid you all are describing, that's the starter relay. The solenoid is the little tube mounted on the starter that you connect the stater wires to. It converts electrical energy into linear motion, engaging the starter gear to the flywheel.
zero-point is offline
post #11 of 11 (permalink) Old 10-09-2005, 12:35 AM
well some cars have the solenoid on the fender wall, and some have them on the starter itselft. it just depends on the year t-bird. so if it's called a different name. sorry, wrong terminology on my part.
