1995 3.8 Timing?? - TCCoA Forums
post #1 of 3 (permalink) Old 10-07-2005, 05:18 PM Thread Starter
1995 3.8 Timing??
What is the timing degree for a 1995 3.8 ? Much appreciated, thanks
Mike
mike884_2 is offline
post #2 of 3 (permalink) Old 10-07-2005, 06:47 PM
Check the emissions label on the hood or the header panel. It should tell you the plug gap, and the base timing.
Jay
FordMan77 is offline
post #3 of 3 (permalink) Old 10-08-2005, 11:34 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
10 degrees.
Thomas is offline
