Hissing noise herd indoors - TCCoA Forums
post #1 of 9 (permalink) Old 11-05-2002, 03:14 PM Thread Starter
Ashish's Avatar
Send a message via AIM to Ashish
Recently I have started to hear a sort of hissing noise, a good description describing it would be, it sounds like when your A/C is on low, but my A/C is not on at all, I thought it was coming from the speakers and that wasn't the problem. When you turn the car off you can still hear it like its going away slowly.
1997 Birdie, its the good one. Limited Edition Sport Sold
9/6/03-9/7/03-J mod & Mark VIII TC 12/26/03-Apten Chip & 03 GT MAF 3/11/04-3/14/04-PI Cams & PI Intake 8/19/04-FRPP 3.73 Diffy2/26/05-SCT chip (burned by Ken B.)
1998 Z28 M6 5.7 LS1
Ashish is offline
post #2 of 9 (permalink) Old 11-05-2002, 03:26 PM
It wouldn't be your supercharger would it? Dumb question, but anything is possible.
HanMan is offline
post #3 of 9 (permalink) Old 11-05-2002, 05:13 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Talking possible
You may be hearing your A/C refrigerant moving around while the pressure equalizes. This will make hissing noises for a short while. Another possibility is the sound of the condesation from your A/C accumulator and condensor dripping onto the passenger side cat. Hope this helps!
-Rob
Rob is offline
post #4 of 9 (permalink) Old 11-05-2002, 11:48 PM
also this happens on mine to but the noise you're describing is different. it could be your a/c mode door (vacuum type?) mine's motorized.
cougar 3.8 is offline
post #5 of 9 (permalink) Old 11-06-2002, 12:17 AM
yeah you mostly likely have a vacuume leak in one of the AC vac hoses behind your dash.
billabong132 is offline
post #6 of 9 (permalink) Old 11-06-2002, 01:17 AM
Alex's Avatar
Send a message via AIM to Alex
Look inside your passenger foot aread below the glove box. You should see a plastic tube going into a valve. If the tube is disconnected, reconnect it. Problem solved.
1991 Mercury Cougar LS (Dead)
1989 Ford Probe LX (Dead)
1989 Ford Taurus SHO (Sold)
1994 Ford Taurus SHO (Dead)
1994 Ford Taurus SHO (Weekend Cruiser)
1999 Honda Accord EX (Daily Driver)
Alex is offline
post #7 of 9 (permalink) Old 11-10-2002, 01:37 AM
I get this in my '90 but it sounds like it's coming from my footwell near the top of the pedals....
Hawaiian Cougar is offline
post #8 of 9 (permalink) Old 11-10-2002, 01:58 AM
power brake booster leaking?
post #9 of 9 (permalink) Old 11-11-2002, 11:52 AM Thread Starter
Ashish's Avatar
Thanks everybody, it was a vacuem hose that was behind the glove box, had come come loose
1998 Z28 M6 5.7 LS1
Ashish is offline
