steering - TCCoA Forums
post #1 of 5 (permalink) Old 10-09-2005, 06:56 PM Thread Starter
steering
Have a problem with steering,my powersteering pump wines,and when I turn left or right the steering seems to stick could it be the pump or rack?
ThunderBird 94 is offline
post #2 of 5 (permalink) Old 10-09-2005, 09:00 PM
The Stevinator's Avatar
do you have fluid in it? mine has been leaking like crazy and I can't seem to track it down yet. i think it may be the high pressure line, or something to do with the steering gear itself. but check the return and high pressure lines. you may just have a leaky hose.
The Stevinator is offline
post #3 of 5 (permalink) Old 10-09-2005, 09:12 PM Thread Starter
yeah it is full
post #4 of 5 (permalink) Old 10-09-2005, 11:40 PM
fl96thunderbird's Avatar
Send a message via Yahoo to fl96thunderbird
my steering did the same thing, but i fill it up every month because of a strange leak around a bolt going through the subframe i guess it is. havent had time to investigate any further.
fl96thunderbird is offline
post #5 of 5 (permalink) Old 10-10-2005, 08:47 AM
a bolt going through the steering gear? i thought about that but don't have a socket or wrench that will fit over it! maybe thats my problem.
