CEL Question - TCCoA Forums
post #1 of 4 (permalink) Old 10-13-2005, 11:33 AM Thread Starter
Resident Line Creator
th3subtl3on3's Avatar
CEL Question
Quick question. Not too sure if its anything to worry about or if its just normal. Is it normal for the CEL light to come on when you are starting the car? It comes on for a few seconds and then shuts off once the car is started. Just want to make sure if it means anything or not. Thanks.
-Brian
th3subtl3on3 is offline
post #2 of 4 (permalink) Old 10-13-2005, 11:39 AM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Yeah, thats normal.
Sold = 96 Thunderbird
Aaron K. is offline
post #3 of 4 (permalink) Old 10-13-2005, 12:17 PM
Traveler's Avatar
If it comes on at the same time all the other lights come on then its just a system check and to let you know that the lights are indeed working. If its staying on after you've started driving, then you've got a code.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 4 (permalink) Old 10-13-2005, 12:47 PM
The Stevinator's Avatar
The Stevinator is offline
