3.8 Mafs - TCCoA Forums
post #1 of 9 (permalink) Old 10-14-2005, 08:22 PM Thread Starter
3.8 Mafs
Did they put different MAFS on 94 3.8?? I found a 94 3.8 and it has a different part # that mine....any idea why??
94ONAIR is offline
post #2 of 9 (permalink) Old 10-14-2005, 08:31 PM
The Stevinator's Avatar
no idea why, but yes there are mass air flow sensors on 94's. maybe someone put an aftermarket one on yours or replaced it with a wrong one.
The Stevinator is offline
post #3 of 9 (permalink) Old 10-14-2005, 09:02 PM Thread Starter
No its the stock one..its just that I found another 94 3.8 and the #'s didn't match up. Some of the numbers did but not all
94ONAIR is offline
post #4 of 9 (permalink) Old 10-14-2005, 09:47 PM
not sure about that, why are you concerned?
post #5 of 9 (permalink) Old 10-14-2005, 10:48 PM Thread Starter
Because it could send the wrong mixture to the computer
94ONAIR is offline
post #6 of 9 (permalink) Old 10-14-2005, 11:10 PM
MN1293-232's Avatar
I wouldnt be worried about it. My personal experience with MAF at least is that they always have had different numbers. If your still skeptical go out to the junkyard and look at all the combos of numbers you can make on the same year/engine. You'll be lucky if you can find one thats close.
MN1293-232 is offline
post #7 of 9 (permalink) Old 10-15-2005, 10:37 AM
yeah, if it runs good, then why sweat it?
post #8 of 9 (permalink) Old 10-16-2005, 09:51 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
because the transfer function is specifically tuned to the computer and engine of the vehicle. Using the wrong MAF can screw up the air/fuel mixture and even send the car into "limp" mode (otherwise known as open loop)
Ford did change some of their part numbers but kept the sensor the same. But as far as I know, they only did that with the 80mm Lightning MAF and nothing else. It's a Part Number, it's not different between each sensor, it should be the same.
-Thomas
Thomas is offline
post #9 of 9 (permalink) Old 10-16-2005, 10:17 PM
i stand corrected by the master.
