Is the problem my alternator?? - TCCoA Forums
post #1 of 3 (permalink) Old 10-18-2005, 05:34 PM Thread Starter
the89bird's Avatar
Here are the symptoms. I start the car, and the volts is one peg below the middle. The little battery below the volts gauge starts flashing, and my beeper sounds. When I get the RPM's up over 1000, the little battery under the volts stops flashing, and the beeper stops it annoying beep. Is this the alternator?
the89bird is offline
post #2 of 3 (permalink) Old 10-18-2005, 10:05 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
it's probably not putting out enough voltage until you spin it higher. It's probably your alternator, but most auto parts store's can check them for free, you might consider trying that.
-Thomas
Thomas is offline
post #3 of 3 (permalink) Old 10-19-2005, 08:33 AM
Johnny Bling Bling
93 lx's Avatar
if it is the alternator, i suggest upgrading to the 94-97 style. it is plug and play, and 130 amps instead of 75 amps.
2009 Ford Flex Limited AWD
93 lx is offline
