need help with the TBI on my bird - TCCoA Forums
post #1 of 8 (permalink) Old 10-24-2005, 01:26 AM Thread Starter
lonerepairman's Avatar
Send a message via Yahoo to lonerepairman
The butterflies on my TBI are stuck closed and i was wondering how to get them to working again. I just bought this one to go along with my other bird cuz they both match and I would like to get it running. By the way the car in question is an 87 t-bird with a 3.8 and an AOD tranny.
lonerepairman is offline
post #2 of 8 (permalink) Old 10-24-2005, 04:21 PM
Drnaline's Avatar
I'd try carb cleaner that is injector safe. Soak the linkage out side of it as well.
Democracy is 2 wolves and a lamb voting on dinner. Liberty is a well armed lamb contesting the vote.
Drnaline is offline
post #3 of 8 (permalink) Old 10-25-2005, 01:22 AM Thread Starter
kk I'll try that. I was also wondering if someone could help me with another problem? my car smokes real bad when i start it and i cant figure out whats wrong. I was told the Head gasket was out on it, cuz it smells like moistier in the fumes. Yet in the same instance it runs great and doesnt miss.
post #4 of 8 (permalink) Old 10-25-2005, 10:43 AM
Drnaline's Avatar
If it just smokes when you start it sounds like your valve seals are leaking oil into the cylinder. Most shops should be able to fix it without removing the head.
Drnaline is offline
post #5 of 8 (permalink) Old 10-26-2005, 02:23 AM Thread Starter
Its not Oil leaking it smells like antifreeze from the exhaust fumes. It also runs but misses on one cylinder.
post #6 of 8 (permalink) Old 10-26-2005, 09:13 AM
Drnaline's Avatar
That sounds like a head gasket. Is your oil level up in the pan or look brownish?
Drnaline is offline
post #7 of 8 (permalink) Old 10-26-2005, 11:44 PM Thread Starter
No. There is no antifreeze in the oil or oil in the antifreeze.
post #8 of 8 (permalink) Old 10-27-2005, 11:49 AM
Drnaline's Avatar
On the valve seals you won't be able to see it leak. It's internal. But if it smell sweet it's kinda gotta be a head gasket if it's coming out through the tailpipe.
Drnaline is offline
