Clicking sound, and bogging down - TCCoA Forums
post #1 of 5 (permalink) Old 10-25-2005, 07:07 PM Thread Starter
The Stevinator's Avatar
Anyone have a problem with getting a clicking sound coming from the front of the engine? it sounds like behind the waterpump or something. also the car boggs down when you give it a little gas, and when you start it up initially.
The Stevinator is offline
post #2 of 5 (permalink) Old 10-25-2005, 08:14 PM
dwinthrup's Avatar
could be your timming chain clicking
dwinthrup is offline
post #3 of 5 (permalink) Old 10-25-2005, 10:19 PM Thread Starter
any solution that doesnt involve taking it off?
post #4 of 5 (permalink) Old 10-25-2005, 10:53 PM
You can try using a mechanics stethoscope or a piece of hose to find out exactly where its coming from before you start taking things apart.
Blue LS is offline
post #5 of 5 (permalink) Old 10-26-2005, 02:23 AM Thread Starter
still doesnt sound right, but i did find a leak. one of my oil cooler lines decided to start rubbing on a transmission line, and the heat caused a hole in the line. so lack of oil pressure i think was the bogging down part. still boggs a little, but i think thats because of my vibration problem (still haven't figured that one out yet), and another minor oil leak from the timing chain cover. tommorow when i have time i think im gonna grab my stethoscope and figure out where that sounds at.
