94 3.8L Stalls/cold Sputters/Hot - TCCoA Forums
post #1 of 4 (permalink) Old 10-27-2005, 12:16 PM Thread Starter
I have a 94 tbird with the 3.8L. the motor was replaced about 40K ago and i am having a problem with it.
when it is cold the engine will randomly stall/rough idle when stopping or parked. when accelerating it runs great/fast great throtle responce.
when is it warm to hot the engine under mid to hard acceleration will sputter/lunge but will not stall/rough idle when stopping. it also has poor acceleration throtle responce.
i have tried cleaing the maf.
any suggestions
thanks
frkyeye is offline
post #2 of 4 (permalink) Old 10-27-2005, 02:54 PM
PCD
Confirmed V6 Nut
Could be an IAC problem. Try cleaning it with oxygen sensor safe carb cleaner.
PCD is offline
post #3 of 4 (permalink) Old 10-29-2005, 09:25 AM
The Stevinator's Avatar
nah, the IAC wouldn't effect it while he was driving. only if he was in idle mode. i would try reading the codes (even if a CEL wasnt thrown). could just be a sensor problem. Those are the worst!
The Stevinator is offline
post #4 of 4 (permalink) Old 10-29-2005, 10:06 AM
Well your at it, check the fuel pressure at the rail. If that is good, then I would think possibly the TPS. The fuel pump wont throw a code, but a weak one gave me the same kinda problems your having. Also a bad TPS doesnt always trigger a CEL, but they will do funny things when they go bad, mine would buck randomly when at highway speeds.
Blue LS is offline
