Car wont start.... bad starter? - TCCoA Forums
post #1 of 7 (permalink) Old 10-28-2005, 03:52 AM Thread Starter
Tom
I need some quick advice, tonight my car would not start. =(
I put the car in run, auto lamps go on (along with dashboard/radio etc.), and I try to start the car, and no luck. It simply makes a moaning like sound that cars typically make before it actually kicks in.
This may be a lame example, but hey, it may help someone out there comprehend what im talking about.
Starting Typical car:
rrrrrrrrrrrrrrrrrrrrrrrrrGGGGGGGGGGRRRRRRRRRRRRRRR RRRRRRRRR
My car:
rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrr
A friendly helper came up to me and told me my starter was bad, he also mentioned that he was a certified mechanic for 26 years.
Ideas? Suggestions? How hard is it to change the starter?
Much thanks.
Tom is offline
post #2 of 7 (permalink) Old 10-31-2005, 05:11 PM
Joseph Rice's Avatar
Send a message via AIM to Joseph Rice Send a message via MSN to Joseph Rice Send a message via Yahoo to Joseph Rice Send a message via Skype™ to Joseph Rice
Starter???
take it off and take it to an Advanced Auto part store to have it checked...
To change it its just a matter of positive and negative putting things where they go. It's easy to locate and change...
Joseph Rice is offline
post #3 of 7 (permalink) Old 10-31-2005, 07:00 PM
The Stevinator's Avatar
changing a start is sooooo easy. do it yourself. and yes, it does sound like your starter is bad.
The Stevinator is offline
post #4 of 7 (permalink) Old 11-01-2005, 02:58 AM
Resident redneck
redneckcougarguy's Avatar
Send a message via AIM to redneckcougarguy Send a message via MSN to redneckcougarguy
hey i did this sunday. locate the solenoid on the drivers side by the battery. take a screwdriver and put it across the two posts. it should try to start. if it doesnt then you need a new starter.
-Steven
Project Rust Prevention: 1990 Buick Regal, Toilet Capacity engine, new trim paint, 57K miles
redneckcougarguy is offline
post #5 of 7 (permalink) Old 11-01-2005, 07:24 AM
well if its the solenoid then everything would turn off, and you would have to disconnect and reconnect the battery (at least thats how it was on mine), and my solenoid was on the starter itself.
post #6 of 7 (permalink) Old 11-01-2005, 10:39 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
us people with the older cars have two solenoids. one right behind the battery, and one integrated into the starter. the "rrrrr" can somtimes be the solenoid being a POS, so my advice would be to (and make sure the car is in park at this time) turn the key to the 'on' position, and connect the two terminals of the first solenoid with a screwdriver (make sure you only touch the plastic handle. And if that does nothing, then do the same to the second solenoid on the starter. If still nothing you can try tapping the starter with a hammer. Sometimes the brushes get out of alignment and tapping the starter nudges them back in to place. If still nothing, then it's time for a new starter.
-Thomas
Thomas is offline
post #7 of 7 (permalink) Old 11-07-2005, 12:22 AM Thread Starter
Tom
Got a new starter, it fixed the problem.
I was suprised when I went to start the car with the new starter that it still takes a few seconds to click. Is there an easy way to make it fire up right away (as is common with new cars)?
Tom is offline
