Oil Pump Going Bad - TCCoA Forums
post #1 of 4 (permalink) Old 11-10-2005, 11:58 AM Thread Starter
The Stevinator's Avatar
Oil Pump Going Bad
Anyone know if the oil pump would make any sort of sound if it was going bad. Or what the symptoms of an oil pump going bad would be?
The Stevinator is offline
post #2 of 4 (permalink) Old 11-11-2005, 12:38 AM
bowez's Avatar
Yes it will make a noise, by what I'm told sort of a grinding/whining sound. Obvious symptom is low oil pressure.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #3 of 4 (permalink) Old 11-11-2005, 07:24 AM Thread Starter
yeah i'm hearing a noise, i'm not sure if its the oil pump or the power steering pump (probably power steering). but my oil pressure is high. i would imagine because i have a good size oil leak im going to have to fix tommorow. thanks
post #4 of 4 (permalink) Old 11-11-2005, 09:51 PM Thread Starter
hell yeah, replaced the O ring and the pump casing tonight, so far (crossing my fingers) no more oil leaking
