question after headgasket replacement - TCCoA Forums
post #1 of 4 (permalink) Old 11-21-2005, 11:46 AM Thread Starter
So I replaced a headgasket this weekend. Car runs million times better no more skipping and stuff. How long before it stops blowing steam out the exaughst?
erics944 is offline
post #2 of 4 (permalink) Old 11-21-2005, 01:41 PM
Did you change the oil? There should be no white smoke once you replaced the leaking gasket.
Blue LS is offline
post #3 of 4 (permalink) Old 11-21-2005, 02:06 PM Thread Starter
drained the oil and put new stuff in. could the cats be saturated with coolent?
erics944 is offline
post #4 of 4 (permalink) Old 11-21-2005, 04:34 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
its possible the cats could be clogged. i opted for the high flow set. should have changed both gaskets at the same time.
2014 GT
1990 300ZX TT
big mike is offline
