will 3.8 sc heads work on a 3.8 non sc motor? - TCCoA Forums
post #1 of 16 (permalink) Old 11-27-2005, 08:19 AM Thread Starter
i need to replace my heads cause the passenger head gasket blew and the head ended up cracking?whats the best thing i should do?i find a lot of people selling sc heads i cant find any from an lx if its not possible to use sc heads what should i do?
csb41502 is offline
post #2 of 16 (permalink) Old 11-27-2005, 11:40 PM
LOLA's Avatar
I don't believe the SC heads will work on a non SC engine. I would check with local parts stores or machine shops for another haed.
LOLA is offline
post #3 of 16 (permalink) Old 11-28-2005, 04:28 AM
You can use them. The SC head is beefier.
post #4 of 16 (permalink) Old 11-28-2005, 07:49 AM
LOLA's Avatar
I'm glad to know this as well. I have read else where that said the SC heads wouldn't work
Than you for setting me straight Joe.
LOLA is offline
post #5 of 16 (permalink) Old 11-28-2005, 09:29 AM
I bet they are beefier. I wasn't worried about the 93 3.8 I bought new blowing up, because I knew the superchargerd version was holding up OK. Boy was I wrong.
Bob
thunderferret is offline
post #6 of 16 (permalink) Old 11-28-2005, 12:30 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Thomas is offline
post #7 of 16 (permalink) Old 11-28-2005, 02:17 PM
What makes the SC heads better than the NA heads in terms of headgasket sealing is the location and number of coolant passages near the combustion chambers.
This is a 89-95 singleport NA head:
This is a 99+ splitport head (the coolant passage design is nearly identical to SC and 96-98 NA heads):
Notice the difference?
-Rod
post #8 of 16 (permalink) Old 11-28-2005, 09:18 PM
1lowbird's Avatar
yeah that head has been deckt a bid A
1989 Thunderbird SC & 1993 Thunderbird LX
1lowbird is offline
post #9 of 16 (permalink) Old 11-28-2005, 09:20 PM
so would the splitport heads fit on a 97 3.8?
NiteFire is offline
post #10 of 16 (permalink) Old 11-28-2005, 09:35 PM
Uber Luber
Thomas's Avatar
say what?
Thomas is offline
post #11 of 16 (permalink) Old 11-28-2005, 09:36 PM
Uber Luber
Thomas's Avatar
yes, but you'll also have to change intakes, throttle body, throttle linkage, egr tube, wiring harnesses, vacuum lines, and ALL kinds of other things.
Thomas is offline
post #12 of 16 (permalink) Old 11-28-2005, 10:47 PM
bowez's Avatar
99+ Heads will work but is about a $1200 conversion, and you must find/make custom Return Fuel Rail.
edited for correct information -Thomas
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #13 of 16 (permalink) Old 11-30-2005, 01:27 AM
As both Thomas and bowez said, it can certainly be done. Actually, 96-97 3.8L MN12's are the easiest to do the splitport swap in IMHO, since they already have DIS. Adding DIS to my 94 LX wasn't much fun.
-Rod
post #14 of 16 (permalink) Old 11-30-2005, 01:49 AM
Uber Luber
Thomas's Avatar
-Rod
Though, SplitPortBird has shown us that with a custom EGR tube, (or obviously, deleting EGR, which was already known) the split-port swap can be done with a distributor
Thomas is offline
post #15 of 16 (permalink) Old 11-30-2005, 02:01 AM
True. I'm just a fan of the better tunability associated with DIS over TFI.
-Rod
post #16 of 16 (permalink) Old 11-30-2005, 10:06 AM
Uber Luber
Thomas's Avatar
-Rod
I feel the same way. I want to switch over to DIS with an EEC-V computer so I can use an X-Cal2
Thomas is offline
