93 , 3.8 throddle body????????? - TCCoA Forums
post #1 of 5 (permalink) Old 11-28-2005, 08:30 PM Thread Starter
1lowbird's Avatar
does anyone know if there is another throddle body other than stock for the n/a 3.8 for 93? I was looking at the bbk 1548 for the 94 mustang and wondering if that will work ? thanks
1989 Thunderbird SC & 1993 Thunderbird LX
1lowbird is offline
post #2 of 5 (permalink) Old 11-30-2005, 07:10 PM
MN1293-232's Avatar
Iam pretty sure the one for the mustang should bolt right up. The only difference might be the linkage. You can also get a 5.0L throttle body to work with some machining work. Ask Thomas about this, he does this sort of thing. The 56mm TB that you want will give you little performance gain on a stock motor. For the price of one of those you can get a lot more performance by doing other things while saving you money. If you do some intake work then I would say it would be worth it.
MN1293-232 is offline
post #3 of 5 (permalink) Old 11-30-2005, 11:15 PM
The Stevinator's Avatar
yeah, if you dont do any intake work its a waste of money. just wait till you at least port the upper intake manifold.
The Stevinator is offline
post #4 of 5 (permalink) Old 12-01-2005, 10:13 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
If you have stock intakes, I wouldnt upgrade your throttle body just yet. If you plan on doing it step-by-step then that would make sense though. But I would spring for the intakes before the throttle body.
I can do a 60mm throttle body for a lot less than that overpriced 56mm BBK.
Thomas is offline
post #5 of 5 (permalink) Old 12-01-2005, 02:46 PM
PCD
Confirmed V6 Nut
I'll vouch for Thomas' work.
PCD is offline
