check engine light - TCCoA Forums
post #1 of 5 (permalink) Old 11-30-2005, 09:42 AM Thread Starter
check engine light
I have a 97 thunderbird 3.8 with about 25 thousand miles on it. The check engine light is on.I had it check an was told I need 4 new 02 sensors.there are 4 cats. Would all 4 go bad at once or is there another problem. I was told That there could be another problem but till I solve this one they can,t tell if there is. Do I really need 4 new o2 sensors or is there just one bad one? Or is it electrical?
redzie407 is offline
post #2 of 5 (permalink) Old 11-30-2005, 07:04 PM
MN1293-232's Avatar
4 oxygen sensors that are all bad at once is pretty rare. If this is the case the car would be running like total crap, if at all. What were the codes you were given, and what symptoms is the car having now?
MN1293-232 is offline
post #3 of 5 (permalink) Old 11-30-2005, 08:13 PM Thread Starter
The car runs great. The codes are
p0135 ho2s11 heater ckt faul
p0161 ho2s22
p0135 ho2s12
po155 ho2s21
p1000 orbit system checks incomplete
post #4 of 5 (permalink) Old 11-30-2005, 10:22 PM
MN1293-232's Avatar
Were these codes read with the engine fully warmed. I have seen similiar codes like these with a cold engine. Meaning if the engine is cold you will get false reading everytime.
post #5 of 5 (permalink) Old 11-30-2005, 11:45 PM Thread Starter
I took the car to pep boys the car was sitting for about a hour.
