Headers for the 3.8 - TCCoA Forums
post #1 of 8 (permalink) Old 12-07-2005, 08:53 PM Thread Starter
MeanGene's Avatar
Headers for the 3.8
I heard that you could find headers from a 3.8 Mustang and mount them to a 3.8 Tbird. Is this true? Is there any real benifit from this? Is there a lot of modification or is it just a bolt on job? What year Mustang is best and will it fit on an 88 3.8?
MeanGene is offline
post #2 of 8 (permalink) Old 12-07-2005, 09:03 PM
they will bolt up yes, but you wont be able to turn your car around
The headers on mustangs will bolt on, but they will hit the steering shaft. You'll need to do the steering shaft mod(search) or get headers for the v6 tbird(Supercoupeperformance.com sells them)
187bird is offline
post #3 of 8 (permalink) Old 12-07-2005, 09:07 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
steering shaft mod = long tubes.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 8 (permalink) Old 12-07-2005, 10:22 PM
AEDM8's Avatar
Or try the 96-97 MN12 headers. Better design than the early style 3.8 headers.
Good for about 5hp....possibly more if you are decently modded.
AEDM8 is offline
post #5 of 8 (permalink) Old 12-08-2005, 12:06 AM
bowez's Avatar
96/97 are the best option per cost (just ask Mike).
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #6 of 8 (permalink) Old 12-08-2005, 12:06 AM Thread Starter
MeanGene's Avatar
But will that fit an 88, and will the bolt right up to the existing exhaust and all the other things that need to work, heat riser, EGR, Ox sensor?
MeanGene is offline
post #7 of 8 (permalink) Old 12-08-2005, 07:33 AM
Motorboatin' SOB
big mike's Avatar
for fitting them, i would get a set of cast iron manifolds cheap, and see if they bolt up. egr and o2 sensor bungs may need modifying. can you get a pic of the egr setup on your engine?
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 8 (permalink) Old 12-08-2005, 09:54 PM Thread Starter
MeanGene's Avatar
Some Pictures Here
I will have to see if I have some of the engine compartment. If not I will take some this weekend.
MeanGene is offline
