Aftermarket Gauge questions... - TCCoA Forums
post #1 of 3 (permalink) Old 11-10-2002, 01:04 AM Thread Starter
Here's the deal, I haev a Cyberdyne H2O temp, and Oil Pressure gauges in an A-pillar pod. Now my question is this. With the H2O temp, if I hook the sending unit up in place of the stock sending unit, it will no longer turn the cooling fan on. If I try somehow to splice the two wires together it makes both of the temp gauges read erratically due to the differing OHMS. So what I can I do to correct this, or where it a good place to tap a hole for the sending unit? I've been thinking about the T-stat housing, but I don't think it's thick enough to have enough thread to keep it from leaking.
Secondly. With the Oil pressure, when I replace the sending unit, it keeps my "Check Gauges" light on all the time since the stock gauge is reading 0 pressure. It's not a big deal except for the fact that I do not have a low fuel light at all, so the "check gauges" light serves that purpose. Same basic question here, where can I tap in to install the oil pressure sending unit?
Mr. 0
Mr. 0 is offline
post #2 of 3 (permalink) Old 11-11-2002, 10:10 PM
See my reply as a new thread, I het the wrong button.
Rick
stardon is offline
post #3 of 3 (permalink) Old 11-11-2002, 10:15 PM
It's under 3.8 " sender mounting".
Rick
stardon is offline
