Lower Intake Gasket - TCCoA Forums
post #1 of 4 (permalink) Old 12-21-2005, 10:08 PM Thread Starter
ECU_Q's Avatar
Send a message via AIM to ECU_Q
Lower Intake Gasket
I think my lower intake gasket is leaking. How hard is it to replace? I planned on taking all that stuff off the get the intakes ported anyway. I was just wondering from the people that have done it already how involved it really is.
ECU_Q is offline
post #2 of 4 (permalink) Old 12-21-2005, 11:49 PM
its not that hard, jsut pull of the throttle cable/cruise cable. then unbolt the egr/related parts, unbolt the upper intake, pull off some vacumm lines, then pop off the fuel lines from the fuel rail, unbolt the lower intake. there are some minor random brackets that will need to come off, as well as the heater hose "hard line" but its not too bad.
187bird is offline
post #3 of 4 (permalink) Old 12-22-2005, 09:02 AM
Yeah, from what I remember when doing the head gaskets in my 89, it was pretty easy, certainly wasn't the toughest part of doing the HGs.
Bangster is offline
post #4 of 4 (permalink) Old 12-22-2005, 03:42 PM Thread Starter
ECU_Q's Avatar
K thanks I just wanted to make sure before I get into something that I might not be able to get out of. Doesn't sound to bad though, thanks again.
ECU_Q is offline
