fuel pump or throttle posit sensor - TCCoA Forums
post #1 of 4 (permalink) Old 12-29-2005, 12:10 AM Thread Starter
orochispice's Avatar
Send a message via AIM to orochispice Send a message via Yahoo to orochispice
Everytime i drive my car after about 5 minutes of running 1.it jerks very badly when i tap the gas. 2.Plus after im at a light for it loses power and cuts of making hard to start. 3.and if im trying to accelerate on the freeway its gets very little gas...all when its cold.
Now i think with number 2 problem i need to get my u joint fixed.
But i dont know what it can be.
Turning a daily driver into a racer is hard work. with no bread you cant do it....so do what i do... plant seeds.
orochispice is offline
post #2 of 4 (permalink) Old 12-29-2005, 05:54 AM
You can start with the simple stuff. How are the plugs, wires, fuel filter, have you cleaned the MAF?
post #3 of 4 (permalink) Old 12-29-2005, 09:41 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
do a tune up. run some seafoam through the engine. you may have a clogged injector.
*waits for the question*
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 4 (permalink) Old 12-31-2005, 06:31 PM
The Stevinator's Avatar
the u-joint would be for problem number 1, take it to a shop to inspect it.
The Stevinator is offline
