cost of 4.2 swap? - TCCoA Forums
post #1 of 11 (permalink) Old 11-11-2002, 11:11 PM Thread Starter
Rob
Rob's Avatar
Send a message via AIM to Rob
Unhappy cost of 4.2 swap?
How much should my friend with a 89 3.8 expect to pay for the 4.2 swap. Also, will the 4.2 bolt up to an AOD? Thanks
-Rob
Rob is offline
post #2 of 11 (permalink) Old 11-12-2002, 12:46 PM
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
I got the engine fully dressed from the recyclers for $1700 with a 1 year warranty. I probably spent another $300 on parts on top of that-- then there is renting the engine hoist. I'd say PLAN for $2300 or so, but I am sure it could be done for much less.
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #3 of 11 (permalink) Old 03-17-2003, 07:57 AM
how much would it cost to have a 4.2 put in from a shop? i dont know how to do anything myself
edit : is this site a good price for 4.2? http://www.nationalengine.com/FordCatalog.htm
will i need a new hood or anything? and also will the shop know to keep my heads and all that stuff?
durdyburdz is offline
post #4 of 11 (permalink) Old 03-17-2003, 08:45 AM
if you get the mustang intake, you wont need a hood. if you get the truck intake, you'll have to get a cobra hood and modify it some. look in PJ's article.
you wont need your heads for the engine. the 3.8L heads wont work w/ the split port intakes...so they'll prolly pull the whole engine, and not take it apart.
weswing04 is offline
post #5 of 11 (permalink) Old 03-18-2003, 09:38 AM
they will pull my whole engine and swap the 4.2 in? i would do the mustang intake because i dont have money for a new cobra hood. how much will all of this cost me if i get it done in the shop?
post #6 of 11 (permalink) Old 03-18-2003, 10:48 AM
You'll have to ask your local shops how much they would charge to do it. Everyone that I know of who has done the swap did it themselves. My entire swap including the splitport engine (I did the splitport 3.8L with the mustang intake) and everything I bought to install DIS and get the engine to run was in the neighborhood of $1500 (the engine was $700 of that). If you're going to have a shop do it, look to spend quite a bit more than that. Good luck.
post #7 of 11 (permalink) Old 03-18-2003, 11:23 AM
DURDYBURDZ, Good to see another Pittsburgh Bird!!
We should meet up some time.
ornithophobia96 is offline
post #8 of 11 (permalink) Old 03-21-2003, 06:58 PM
just curious, what was involved in switching the car to DIS?
edgar is offline
post #9 of 11 (permalink) Old 03-21-2003, 07:13 PM
You have to have an EEC that supports DIS, with a matching DIS module, Cam sensor, crank sensor, and coil pack. It's pretty complicated, involves a LOT of wiring/soldering and time. If you attempt it, my suggestion is that you first buy the necessary wiring diagrams, one for the way your car is now and one that matches the DIS system you're using. Then draw your own diagrams, and then make a numbered list of what wires will be changed in what order. But like I said, it's pretty complicated.
post #10 of 11 (permalink) Old 03-22-2003, 06:32 AM
you wouldn't need to convert to DIS, there is someone on here that got the 99+ mustang upper intake to fit a distributor car buy just removing the EGR setup off that intake. If you live in an area that doesn't have Emissions testing that would be the perfect choice for you.
rancherlee is offline
post #11 of 11 (permalink) Old 03-22-2003, 09:13 AM
Yes, it is possible to run a distributor with the mustang intake, but just as rancherlee said, that means no EGR plus a few other mods.
