Bad Smell and a CEL - TCCoA Forums
post #1 of 16 (permalink) Old 01-12-2006, 07:42 PM Thread Starter
ECU_Q's Avatar
Send a message via AIM to ECU_Q
Bad Smell and a CEL
Being that it was nice today I decided to take the car out on a little joy ride.
I got up to about 100 before I noticed a bad exhaust smell. The car wasn't heating up or anything like that, the exhaust just started to smell really really bad.
Then the check engine light came on.
So I got off the gas and it started to slow down and the smell started to go away.
However the check engine light went on and off about 3 more times.
My first guess is either the cat. converter based on the smell, or the o2 sensor, based on the light. No one around here has a scanner that I can use without paying 80bux for it so I just want to hear what some of you guys think about it first.
ECU_Q is offline
post #2 of 16 (permalink) Old 01-13-2006, 07:52 AM
Gcline's Avatar
go to auto zone and have them test it for you
Daily Driver, 38mpg!
Gcline is offline
post #3 of 16 (permalink) Old 01-13-2006, 08:53 AM
You can get the codes using a paperclip, I don't know if Autozone does pre OBD-II cars or not. I bought a 20 dollar OBD-I reader since I have the 89 Cougar, my parents have 3 OBD-I cars, and at the time I had another OBD-I car. Makes it easier but you can do it many ways.
I think it sounds like the car was running super rich, or incomplete combustion. Probably have an O2 code about a rich condition, but I would get the codes and see.
Bangster is offline
post #4 of 16 (permalink) Old 01-13-2006, 10:00 AM
PCD
Confirmed V6 Nut
Advance Auto lends out a reader that does both OBD I and II cars. they will also print out the codes. ALL THIS IS FREE.
PCD is offline
post #5 of 16 (permalink) Old 01-19-2006, 11:02 PM Thread Starter
ECU_Q's Avatar
Ok so I was heading out to either Autozone or Advance. I was on my way down there and the check engine light went off. It still has a bad smell but no light anymore.
I notice that the light comes on, the smell gets stronger, and the car loses power whenever its warm outside.
Any ideas?
ECU_Q is offline
post #6 of 16 (permalink) Old 01-19-2006, 11:44 PM
Gcline's Avatar
advance doesnt let you borrow a machine, i work there lol
Gcline is offline
post #7 of 16 (permalink) Old 01-19-2006, 11:58 PM
dunno....... sounds like cats....
FunktasticLucky is online now
post #8 of 16 (permalink) Old 01-20-2006, 08:46 AM
when the cars on and you start to getting that bad smell pull over and get out of the car and look under it usually if cats are on there way out they start to glow red try doing that next time
dash is offline
post #9 of 16 (permalink) Old 01-20-2006, 09:55 AM
PCD
Confirmed V6 Nut
GCline, I work at Advance #5001. We program the scanner and let people take it to the lot to read their codes, then we print them out for them.
PCD is offline
post #10 of 16 (permalink) Old 01-20-2006, 10:21 AM
The Stevinator's Avatar
yeah sounds like cats. i would just go buy a code reader dude, they're cheap for obd I, i would imagine your throwing a code from your o2 sensors. try unplugging your battery for awhile to reset the computer. see if it does it again.
The Stevinator is offline
post #11 of 16 (permalink) Old 01-21-2006, 10:00 PM Thread Starter
ECU_Q's Avatar
It depends on the area. I worked at an Advance in North Carolina and we did the same thing. When I came back up to Delaware the local Advance doesn't offer that service. Now I'm at a Pepboys and that really sucks. lol.
Yea I'm probably going to just buy the code reader and then go from there. It would be a good excuse to get some high flow cats though.
I did try and pullover one day to see if the cats were glowing and they weren't so I never really thought they were the problem. But you never know.
Thanks for your input guys.
ECU_Q is offline
post #12 of 16 (permalink) Old 01-21-2006, 10:22 PM
well it may be that they already burned up. The honeycombs may have just totally deteriorated already. Do they make a rattling sound?
post #13 of 16 (permalink) Old 01-21-2006, 10:40 PM Thread Starter
ECU_Q's Avatar
No, no rattling sound at all. The car doesn't sound any different or anything like that. Just a really bad smell. Its to the point where sometimes you have to crack the window because its starts to smell inside the car now.
ECU_Q is offline
post #14 of 16 (permalink) Old 01-22-2006, 12:10 PM
Audiobahnbird's Avatar
Send a message via AIM to Audiobahnbird
sounds like a baby climbed into your tailpipe and you just roasted it. good job, that'll make an interesting episode of "without a trace"
Please enjoy my new and improved short signature- Russ
Audiobahnbird is offline
post #15 of 16 (permalink) Old 01-22-2006, 01:21 PM
Wtf???
post #16 of 16 (permalink) Old 01-22-2006, 02:08 PM
babys dude? no, its obviously unicorns. tiny mythical horned horses are runing around in his exhaust system. hahaha, ah dane cook is the man...
