Engine Swap - TCCoA Forums
post #1 of 5 (permalink) Old 01-20-2006, 01:07 PM Thread Starter
OTOWNBIRD's Avatar
Engine Swap
Need a little help...
I have a 1995 thunderbird with a 3.8. Theres a Rod knocking in the motor so its time to swap.
I have access to a 2000 mustang 3.8 for next to nothing with 25,000 on it.
I would like to purchase that motor and upgrade the cam.
Will this motor fit into the Bird. Do I need to change the existing computer. And Im pretty sure the existing tranny will work.
Any thoughts or suggestions.
Thanks in advanced
OTOWNBIRD is offline
post #2 of 5 (permalink) Old 01-21-2006, 03:14 AM
i asked the same question not too long ago check out the 4.2L swap article it can be done
dash is offline
post #3 of 5 (permalink) Old 01-21-2006, 05:36 AM
PCD
Confirmed V6 Nut
Since you have a 95 with a DIS in place, a 2000 3.8L ought to drop in. It is the same block. All your accessories will bolt up to it. Racecougar put a 2000 3.8L in his 94, but had to convert to a DIS since the 94 had a distributor.
Also, you'll get more HP from the 2000 engine. Enfoy!
PCD is offline
post #4 of 5 (permalink) Old 01-21-2006, 06:07 AM
He might not. I believe only the California cars had DIS.
DIS wasn't the norm until 96.
post #5 of 5 (permalink) Old 01-21-2006, 12:30 PM
That's correct. Unless he has a California Emissions car, he doesn't have DIS. That means wither converting to DIS, or deleting/moving the EGR to clear a distributor.
There is a fair amount of info about this swap here on the site. I'd suggest searching for "splitport" and "splitport swap".
The engine will fit under the stock 94-95 Tbird hood, after modifying/making/moving a few brackets.
-Rod
