? on 4.2 swap - TCCoA Forums
post #1 of 19 (permalink) Old 01-25-2006, 10:20 AM Thread Starter
? on 4.2 swap
Is it necessary to change the accessory bracket on a 4.2 to a 3.8 style bracket. also would cutting a hole in the factory hood weaken it? I plan to temporarily to cut a hole n the hood to allow the truck intake to work on the car then add a cowl hood until i can afford to by a new one. Also how would the car run with the egr deleted and no tune?
-John
platinummotorsports is offline
post #2 of 19 (permalink) Old 01-25-2006, 10:37 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i would think that you reuse your own brackets. cutting a hole should not weaken the hood. no egr and no tune, it would most likely run like crap. do a search.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 19 (permalink) Old 01-25-2006, 12:23 PM Thread Starter
would rain affect a engine if i just leave a hole n the hood just for the intake to come out
post #4 of 19 (permalink) Old 01-25-2006, 12:53 PM
Motorboatin' SOB
big mike's Avatar
if its a little rain, it would probably be ok. its ok for the engine to get wet, but i wouldnt drive it heavy rain.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 19 (permalink) Old 01-25-2006, 01:22 PM
tbirdtess's Avatar
4.2 V8?
Hello
The brackets are different from a 3.8 V6 to a 4.2 V8
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #6 of 19 (permalink) Old 01-25-2006, 01:50 PM
Motorboatin' SOB
big mike's Avatar
4.2 v6, came in f150's
2014 GT
1990 300ZX TT
big mike is offline
post #7 of 19 (permalink) Old 01-25-2006, 02:07 PM
PCD
Confirmed V6 Nut
3.8L and the 4.2L are the same block. Big difference is the crank. I'm not sure if the pistons are different or not. I'll hae to check that out next time I'm at work at Advance.
Platnium, all your accesories are the same between the 4.2 and the 3.8.
Have you thought of using 2000 Mustang upper and lower intakes gasket matched to each other and to the heads? It should fit under the stock hood without cutting it.
PCD is offline
post #8 of 19 (permalink) Old 01-25-2006, 02:11 PM Thread Starter
ive thought about it but i dont want to have to change to DIS so thats why i wanted the truck intake plus i am basing my setup similar to pj's. plus ive heard that the mustang intake kinda restricts the 4.2 . im not sure about that but i read about it on v6power.net. also so basically all i have to do is take my accesories of my 3.8 and put them on the 4.2 .
post #9 of 19 (permalink) Old 01-25-2006, 08:09 PM
you won't need a tune for just removing the EGR valve, you WILL need it for the added displacement and larger injectors though.
rancherlee is offline
post #10 of 19 (permalink) Old 01-26-2006, 07:30 AM
If you eliminate the EGR you can go with the Mustang upper intake and the distributor.
post #11 of 19 (permalink) Old 01-26-2006, 10:09 AM Thread Starter
How is that possible. i dont think the egr would have an effect on the position of the upper intake. except maybe it would get get in the way.what if i tried to use a spacer or the intake
post #12 of 19 (permalink) Old 01-26-2006, 10:17 AM
The distributor will be in the way of the EGR valve if you go with the Mustang upper, thats why racecougar went DIS.
post #13 of 19 (permalink) Old 01-26-2006, 01:39 PM
PCD
Confirmed V6 Nut
I got one small question. Are the 4.2 pistons shorter than 3.8 pistons, or are they the same piston?
I'm winnowing the wheat from the chaff for my project.
PCD is offline
post #14 of 19 (permalink) Old 01-26-2006, 04:44 PM
different pistons, same rods as the 96+ 3.8L though.
post #15 of 19 (permalink) Old 01-26-2006, 09:38 PM
Or you could keep the egr and distributor and go with the Mustang intake like I did.
zero-point is offline
post #16 of 19 (permalink) Old 01-26-2006, 10:56 PM Thread Starter
do you have more pics of this setup. looks good. how does your hood fit? how did you the distributer there if split port 3.8s from mustangs had dis. feel free to pm me. thanks
-JOHN
post #17 of 19 (permalink) Old 01-27-2006, 08:23 AM
-JOHN
Thats the easy part, pulls the Camsensor and drive unit out and slide your old distributor in.
post #18 of 19 (permalink) Old 01-27-2006, 10:24 AM Thread Starter
thanks rancherlee. so i am assuming that this would be the same on the 4.2 v6 from a F-150
Is the EGR neccessary to pass emissions.
And how do get vacuum to the imrcs.
post #19 of 19 (permalink) Old 01-28-2006, 11:26 PM Thread Starter
Could a moderator close this post i am going to just put a 2000 mustang 3.8 in my car. much cheaper and almost same power. found a couple near me for 500 or less.
