Changing Idler Pulley Tomorrow Where is Belt tensioner? - TCCoA Forums
post #1 of 7 (permalink) Old 01-25-2006, 09:21 PM Thread Starter
yeah the bearing in my idler pulley is howling at me and its got dimples in it so i need to replace it and i wanna do it myself but i need to know where the belt tensioner is so i can take the belt off
DeeDeeArrGuy is offline
post #2 of 7 (permalink) Old 01-25-2006, 10:23 PM
Litning's Avatar
under your air conditioner pump
Litning is offline
post #3 of 7 (permalink) Old 01-26-2006, 09:25 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
hope you got guns for arms. that tensioner is tough to swing up. im pretty sure its an 11/16" bolt. a little advice: dont start your wrench or ratchet from the 6 o'clock position and rotate the tensioner. if you do, the tensioner will swing back past where it was with the belt on and your wrench or ratchet will get pinned up against the k-member, and will be tough to remove from the tensioner bolt. start your wrench/ratchet from around the 4 o'clock position.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 7 (permalink) Old 01-26-2006, 01:57 PM
PCD
Confirmed V6 Nut
Mike, you must have a strong spring in your tensioner. I can move it, and my 16 year old daugher can do it, too.
PCD is offline
post #5 of 7 (permalink) Old 01-26-2006, 02:00 PM
Motorboatin' SOB
big mike's Avatar
nah, im just weak
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 7 (permalink) Old 01-26-2006, 05:49 PM Thread Starter
i was bout to say it wasnt that hard i pulled it and took the belt off by myslef. but anyways the bearing on the stock pulley was shot to he-l-l and the wheel had dimples in it. picked one up at the junkyard on the way home from school =]
post #7 of 7 (permalink) Old 01-26-2006, 09:14 PM
Motorboatin' SOB
big mike's Avatar
yeah, when you are a little guy like me, easy jobs for other people can be tough for me.
2014 GT
1990 300ZX TT
big mike is offline
