idling rough - TCCoA Forums
post #1 of 5 (permalink) Old 02-01-2006, 11:15 AM Thread Starter
idling rough
car is idling very rough.. i did clean the engine out last week do you think i got water in the spark plug holes an it caused this? or might it just be something else? the car accelerates and drives fun.. only at a stop its shaky/vibrating
HiFi is offline
post #2 of 5 (permalink) Old 02-01-2006, 12:21 PM
do you have a distributor or DIS? could also be your MAF
rancherlee is offline
post #3 of 5 (permalink) Old 02-01-2006, 03:07 PM Thread Starter
i dont know.. its a '94 3.8L
HiFi is offline
post #4 of 5 (permalink) Old 02-01-2006, 04:30 PM
idle air control
Advanced auto can have one shipped for under fifty dollars in a day or two and your problem will be solved. As age takes its toll, along with dirt and water, your idle valve slides instead of adjusting. There is an aerosol spray solution for the MAF sensor you can spray via induction tube. Hopefully it'll help. How many miles are on the car?
XR7IST is offline
post #5 of 5 (permalink) Old 02-01-2006, 04:33 PM Thread Starter
85K miles. i guess u guys dont think its teh spark plugs. are you sure its the IAC? is there any way to check to be sure before i spend the money replacing it.
HiFi is offline
