93 ford t-bird misfire and rough idle - TCCoA Forums
post #1 of 7 (permalink) Old 01-25-2006, 09:04 PM Thread Starter
Hopefully someone can help. I have a 93 t-bird v6 3.8ltr. I put a new engine and transmission in it. I drives and runs great, seems to lack a little power though. At idle it sputters and eventually dies. I set the idle at 550rpm and the timing at 10 deg. BTC. I sit and watch with a timing light and for about 20 seconds the timing is good, then out of no where it jumps aroud and sputters, the timing goes from 20 BTC to 10 ATC back and forth then dies. If i rev it up to 800+ rpm then the timing goes strait to 10 btc and doesnt move. I put all new sensors, air idle control valve, throttle position sensor, cap and rotor, plugs and wires, even fuel pressure regulator. I am stumped and have dumped a few thousand into the car now. Please help. A friend tells me that since the engine is bigger now that the computer will need to be reprogrammed to compensate the new fuel air mix. But I thought O2 sensors did this? Please any advise to avoid taking it to ford. Thank you
baggedbird93 is offline
post #2 of 7 (permalink) Old 01-27-2006, 10:48 AM
bad93bird's Avatar
Just a suggestion. What about the ignition control module? You replaced everything but the MAF. Do V6's have them? I'm not sure. If they do, then try it also. If all of that gets done and no improvement, replace the PCM or check the wiring harness.
bad93bird is offline
post #3 of 7 (permalink) Old 01-27-2006, 06:13 PM Thread Starter
before replacing anymore expensive parts... Is there a way to check these parts?
post #4 of 7 (permalink) Old 02-01-2006, 11:06 AM
bad93bird's Avatar
No, not really unless you know someone with the exact same car as you to swap out on. I would really check all of the wiring harnesses. Make sure all of them are good and tight, especially at the PCM.
post #5 of 7 (permalink) Old 02-01-2006, 04:41 PM
check your idle air control unit. this regulates the car's IDLE... hence its name. new costs around $50.00
XR7IST is offline
post #6 of 7 (permalink) Old 02-01-2006, 07:05 PM Thread Starter
I replaced the idle air control and the throttle position sensor from the get go. Damn i guess i will have to go to ford finally....
post #7 of 7 (permalink) Old 02-01-2006, 07:29 PM
The Stevinator's Avatar
yeah, i would at least CLEAN your MAF first before replacing it. it is one possibilty for your problem. why is the engine bigger now? what did you do to it?
The Stevinator is offline
