What was Ford thinking? - TCCoA Forums
post #1 of 6 (permalink) Old 02-05-2006, 12:13 AM Thread Starter
maiden_fan's Avatar
I don't know who has had their heater hose off the 95 3.8 but it seems to me like it is the poorest setup possible. How is steel on steel supposed to seal? I'm talking about where the hose goes into the water pump. I bought an O-ring for $7.50 that turned out to be the exact same thing we have in our O-ring set painted orange and I can't figure out how to put it all back together without it leaking. I wasn't here when it was pulled off, I was at college, my grandpa pulled it off and he doesn't remember an O-ring even being on there but there is supposed to be one. I guess my question is, how in the heck do I make this thing seal.
A guy walks into an autoparts store and says "I would like a windshield wiper for my Honda Civic." The clerk thinks a minute then says "I guess that's a fair trade..."
The Yuwie Test[/URL]
maiden_fan is offline
post #2 of 6 (permalink) Old 02-08-2006, 12:55 PM
are you talking about the metal bypass pipe that goes into the water pump? there should be an o-ring there and if I remember correctly, a bolt holds it in place.
Wicked6 is offline
post #3 of 6 (permalink) Old 02-08-2006, 03:51 PM
there is an oring that goes on it, and there is also a screw that holds it down on top of the waterpump. get one of the "X rings" and that will keep it from leaking. .
187bird is offline
post #4 of 6 (permalink) Old 02-08-2006, 07:22 PM
The Stevinator's Avatar
yeah, a good deal of silicone around the edges after you bolt it down will help too.
The Stevinator is offline
post #5 of 6 (permalink) Old 02-09-2006, 12:24 PM Thread Starter
maiden_fan's Avatar
The problem is the O-ring doesn't really do much good and the way they designed it to screw in will pull the hose out of the hole if the bend in the bracket is even slightly off. I did silicone it up pretty good and we'll see what happens but I just think it is a poor design.
post #6 of 6 (permalink) Old 09-07-2006, 11:16 AM
got the same problem w my 3.8, whats an x ring, where to get it?, any hints on how to stop this hose pipe from leaking?
mgretro is offline
