Ever done an oil pump in a 3.8 - TCCoA Forums
post #1 of 3 (permalink) Old 07-14-2002, 11:13 PM Thread Starter
I haven't (yet LOL) this is my weekend project for a buddy of mine.
I have 3 questions.
1 where the frag is the pump is outside the pan or in the pan.
2 if it's in the pan how high do you have to raise the engine to get to it?
3 will a SC pump work on a non SC block?
Blitzcat is offline
post #2 of 3 (permalink) Old 07-16-2002, 06:44 PM
Wink
The oil pump beleive it of not, is the same place where the oil Folter attaches, so it's outside the block, now when I did my SC's oil pump I did it with the motor out of the car, but it looks like with a LOT and I mean ALOT of time and care you could do it with the motor in the car, as for thew possibility of the SC oil Pump, I don't know, but I'm sure it's a yes, since I've accedentally received the wrong oil pump and it fit fine it just flowed a whole lot less... your best bet is a 94-95 SC oil pump if the do fit... they where and upgraded design the tried to make up for the lack of decent oiling in the 3.8's.
Jim
Cheetah is offline
post #3 of 3 (permalink) Old 07-18-2002, 01:09 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
all 3.8 fords the same
All 3.8 Fords have the oil pumps built into the front cover. You can just buy a rebuild kit. It comes with new gears and some other stuff(its been a year and half since i did it). Be sure to prime the pump when you put it back on!! :-)
-Rob
Rob is offline
