HELP! Fuel injector question - TCCoA Forums
post #1 of 5 (permalink) Old 11-17-2002, 10:19 PM Thread Starter
Exclamation HELP! Fuel injector question
I need to know the resistance required to fire fuel injectors for a 1994 3.8L N/A and fuel injectors for a 1994 3.8L SC. Thanks for any help.
post #2 of 5 (permalink) Old 11-18-2002, 07:56 AM
I believe all injectors fall into to catagories, High Impedence and Low inpedence. The cross over point is somewhere around 50# injector. I look for the info later today to find out for sure. A 14#, 19#, 24#, 30#,38#, and 42# are all in the same catagory and work just fine with the stock computer
rancherlee is offline
post #3 of 5 (permalink) Old 11-18-2002, 08:54 AM Thread Starter
I agree that they fall into low impedence and high impedence, but I don't think that pound ratings have anything to do with that. The rating just tells you what size the injector is, not what resistance it requires to fire.
post #4 of 5 (permalink) Old 11-18-2002, 05:18 PM
jim
dont have the answer to your question but did you convert to the DIS with the split-port swap in the 94?
jim is offline
post #5 of 5 (permalink) Old 11-18-2002, 08:29 PM Thread Starter
Yes I did, it was a real fun swap too (note my extreme sarcasm). To put it bluntly, it was an extreme amount of wiring, but I can say that it does work (I'm getting spark). As soon as I get the car to run I'll see about writing up a tech article on the swap.
