???MAFs on T-birds??? - TCCoA Forums
post #1 of 11 (permalink) Old 11-18-2002, 02:42 PM Thread Starter
Question ???MAFs on T-birds???
I know what a MAF does and where they are most commonly placed in the engine bay. What I don't understand is everyone that I have talked to or pics that I have looked at say that it is inline from the air box to the TB. I don't have one on my car. I don't have an SC, but from what I understand, even the 3.8l LXs are to have MAFs in this place. Does anyone know why I don't have one on my car and better yet should I have one. I haven't found any unplugged connecters so I am left to think that I don't need one or it is located somewhere else.
ThunderHawk SVT is offline
post #2 of 11 (permalink) Old 11-18-2002, 03:56 PM
Refrigerator Raider Hater
GreenBird's Avatar
89 and 90 3.8L NA's do NOT have a MAF.
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #3 of 11 (permalink) Old 11-18-2002, 05:10 PM
You have a MAP sensor in place of the MAF.
Jim
1993 LX 5.0
JSGAuto is offline
post #4 of 11 (permalink) Old 11-18-2002, 05:18 PM Thread Starter
Ok, Thanks for the information about the MAFs. Just one other thing if you who replyed should know. Why doesn't the 89-90s have a MAF? What did they do differntly to the engine to require one?
post #5 of 11 (permalink) Old 11-18-2002, 05:21 PM
jim
need maf, different harness, different computer
jim is offline
post #6 of 11 (permalink) Old 11-18-2002, 05:22 PM
They have more accurate readings of the air flow, and basicly an all out different design to read airflow. But the problems with them are; more expensive then the MAP and they are known to go bad more often.
Jim
1993 LX 5.0
JSGAuto is offline
post #7 of 11 (permalink) Old 11-18-2002, 05:56 PM Thread Starter
Ok, Thanks, Just wanted some more knowledge.
post #8 of 11 (permalink) Old 11-18-2002, 09:59 PM
Can the MAP still be used on an SC Engine by usin the same valve covers and such or is that totally out of the question?
Willow9238 is offline
post #9 of 11 (permalink) Old 11-19-2002, 02:03 PM
GreenBird's Avatar
Ford didn't use a MAF on 89-91 3.8L na's because they didn't have to. a AMP is good enough in most cases.
You can't just add a MAF, your computer will not recognize it.
Youcan run without a MAF, but whatever gains you think you'll get by not using a MAF will be more than offset by the crappy a/f ratio you will get.
96 Alpine Green V8
post #10 of 11 (permalink) Old 11-19-2002, 02:52 PM
Cougar Pilot
BlackCat94's Avatar
My 1991 Cougar LS has a MAFS
TCCoA, there's no better way.
BlackCat94 - The Revolution.
BlackCat94 is offline
post #11 of 11 (permalink) Old 11-19-2002, 09:52 PM
I think he meant 89-90 N/A !
