91 N/A 3.8 Power Steering help... - TCCoA Forums
post #1 of 2 (permalink) Old 11-21-2002, 01:20 AM Thread Starter
Ok, I need to replace the pressure hose on my power steering pump. The parts stores keep asking if it has Variable Speed assisted streering or not. How can I tell? I am not the original owner, nor do I have an owners manual for the car. Also, anyone else done this yet? Difficulty level? It doesn't look that bad, just a little cramped for space. Any info would be great. Thanks y'all...
Steve
91GoldCat is offline
post #2 of 2 (permalink) Old 11-24-2002, 06:47 PM Thread Starter
Quick Disconnect????
Ok guys and gals... Here is the question... I got the hose changed out. But, there is a "Quick Disconnect" fitting on the hose. Any clue why this is there? I had to move it from the old hose to the new hose. It looks similar to an R134a Freon connection. The rubber cover that was over it has seen better day. I was just wondering what it is for and why it is there. See Photo below... Thanks... Steve
