timming cover.. - TCCoA Forums
post #1 of 10 (permalink) Old 11-24-2002, 10:54 AM Thread Starter
anomnity's Avatar
timming cover..
would i have to remove the oil pan to get this item off? THanks.
Solid Black 1987 T-bird 5.0
anomnity is offline
post #2 of 10 (permalink) Old 11-24-2002, 12:25 PM
Nope, just DON't forget the single SMALL allen head bolt by the oil pump, you WILL crack the cover otherwise as I did! (nothing a little JB weld didn't fix though)(
rancherlee is offline
post #3 of 10 (permalink) Old 11-25-2002, 11:42 AM Thread Starter
anomnity's Avatar
yeah i know i saw..hehe..they call it a cap screw i think...
thanks for the info man, you saved me some work..!!
anomnity is offline
post #4 of 10 (permalink) Old 11-26-2002, 04:24 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
why are you removing it dude???? is it leaking???? i think i have a really small leak im not sure but the front screws were kinda loose so i tighten them up, lets see if it fixed the problem. Isnt there a recall on the timing belt covers for the 3.8s???
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #5 of 10 (permalink) Old 11-26-2002, 10:35 PM
I know there was one for the 96-97 3.8.
post #6 of 10 (permalink) Old 11-27-2002, 01:17 AM Thread Starter
anomnity's Avatar
oh no oh no..if it were leaking id just say who cares..
my chaing is really really bad and it jump some teeth....and well i havent driven it in almost a month..i think i can turn my crank 16degrees before the rotor moves..so..lol
and just when i was putting it on TDC to remove dist. it was jumping teeth..so...yeah...small leaks dont bother me,..
anomnity is offline
post #7 of 10 (permalink) Old 11-27-2002, 05:12 AM
so i shouldnt bother with it, well the good thing is that its just a realllll small leak its like the gasket itself looks green but its not leaking anywhere. I tightened the screws on the front lets see what happens.
Marvin M.
Back in the game!!!
post #8 of 10 (permalink) Old 11-27-2002, 08:52 AM Thread Starter
anomnity's Avatar
yeah if it still does..just clean it some and put some silicon over it, it should slow it down even more.
anomnity is offline
post #9 of 10 (permalink) Old 11-27-2002, 08:55 AM
kewl sounds like a plan, thanks for the help anomnity ill do that.
Marvin M.
Back in the game!!!
post #10 of 10 (permalink) Old 11-27-2002, 02:47 PM Thread Starter
anomnity's Avatar
no prob.
anomnity is offline
