tb size modifications - TCCoA Forums
post #1 of 14 (permalink) Old 11-26-2002, 12:36 PM Thread Starter
Send a message via AIM to rzimmerl
ok have half shafted the tb. now am going to have the ridge removed in the center section. what size should i have it bored to. 52mm is what the intake manifold side is. not sure if that is the size i can go with or can i go bigger than 52. also will i need a new butterfly plate if so where can i get one.
thanks
ryan
1990 SC AOD 1.7L AR....11.75 @118
441 RWHP 435 RWTQ
rzimmerl is offline
post #2 of 14 (permalink) Old 11-26-2002, 12:53 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
hey sorry this is out of your question, but how does your cat-back sound catless b/c right now im catless and i want to get the cat-back system does it sound very loud??????????? thanks for the help
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #3 of 14 (permalink) Old 11-26-2002, 01:18 PM Thread Starter
havent had time to get it on the lift yet to take them out have been busy with school. will prob do it in a couple weeks. but the flowmaster system sounds good, has a deep tone to it and isnt loud on the highway.
441 RWHP 435 RWTQ
rzimmerl is offline
post #4 of 14 (permalink) Old 11-26-2002, 01:20 PM
is it very noticable??????????? how can you describe the sound, acording to another cars sound like a mustang or so. So i can have an idea.
Marvin M.
Back in the game!!!
post #5 of 14 (permalink) Old 11-26-2002, 01:30 PM Thread Starter
its noticeable but not like a mustang. the delta flow mufflers are quiet but you can still here it coming down the street. it has the sound of a v8 just a quiet one the resonator is what makes the car sound better. seemed like had a noticeable difference off the line and just easier flowing up top. prob will make more of a difference after i unplug my cats
441 RWHP 435 RWTQ
rzimmerl is offline
post #6 of 14 (permalink) Old 11-26-2002, 04:33 PM
Any Boring will require a new bigger Throttle plate, where to find one, I don't know.
rancherlee is offline
post #7 of 14 (permalink) Old 11-26-2002, 07:58 PM Thread Starter
can i make 52 mm all the way through. by removing the ridge where the butterfly is with out any problems with idle.
441 RWHP 435 RWTQ
rzimmerl is offline
post #8 of 14 (permalink) Old 11-26-2002, 08:52 PM
hey zimmer, is that dyno WITH all the mods you have listed in your signature??? If so it seems a little low.....
That just cannot be....
Spike is offline
post #9 of 14 (permalink) Old 11-26-2002, 09:02 PM Thread Starter
ya it was except for the cat deletes accel cap and rotor, new plugs and wires they were worn out over 2 years old. replacing o2's maybe an old fashioned tune up is what i needed for power hope to run another one in january with the intakes, 97 headers, just finished halfshafting the tbody and ported it will post the numbers when get it all set up an ran. car has 75000 miles on it
thanks to espicer, rancherlee for the help on halfshafting, was really easy to do with spare parts layin around
441 RWHP 435 RWTQ
rzimmerl is offline
post #10 of 14 (permalink) Old 11-26-2002, 09:09 PM
Hmmmm I've been talkin with a few other people on here and they seem to have the same opinion as me: the TQ looks good but something just ain't right with the HP there man... according to that you've only gained 5 or so HP at the crank from stock... and that can NOT be. Maybe rancher can post again on the subject, or SD even.
Spike is offline
post #11 of 14 (permalink) Old 11-26-2002, 10:15 PM Thread Starter
Talking
finally realized cant bore the tb because has to be closed at idle for the idle air motor unless can get a bigger butterfly. but any info on what i need to do for my
hp numbers WOULD BE GREATLY APPRCIATED[SIZE=3]
441 RWHP 435 RWTQ
rzimmerl is offline
post #12 of 14 (permalink) Old 11-26-2002, 10:23 PM Thread Starter
here is the dyno sheet if it shows up[IMG]C:\Documents and Settings\Ryan\My Documents\My Pictures\Others[/IMG]
441 RWHP 435 RWTQ
rzimmerl is offline
post #13 of 14 (permalink) Old 11-28-2002, 12:19 AM
What is Halfshaft??
What does that mean?? If there's a gain in power I'd like to do it, but don't know what it means??
XR7kid is offline
post #14 of 14 (permalink) Old 11-28-2002, 07:13 AM
DAMN your RWTQ is high You have about 20-25ft-lbs. over stock but LITTLE to NO gain in HP
STOCK is about 115-120rwhp and around 190 rwtq
On though the comes to mind "was the torque converter locked for the dyno pull?"
If you torque converter was lock you would loose torque but gain HP. with you mods I would say you SHOULD be around 130rwhp and 200rwtq
