Power Braking question - TCCoA Forums
post #1 of 19 (permalink) Old 11-27-2002, 11:26 AM Thread Starter
Ok when i powert brake my car it does great but the problem is is that only the left rear tire spins but the other left don't, I think. But i was wondering what could make them both spin at the same time? Would a 5.0 make it work? Thanks
89T-BirdLX is offline
post #2 of 19 (permalink) Old 11-27-2002, 11:33 AM
My 96 V6 when i power brake it i belive that both tires spin. I think that they just swith back and forth between thte tires. Were as my SC spins both on them at the same time. I dont know about the V8 ones though. Which model do you have?
romigh871 is offline
post #3 of 19 (permalink) Old 11-27-2002, 12:01 PM
What you need is a trac-loc or another type of limited slip differential.
Check out this site it is pretty cool.
http://www.howstuffworks.com/differential.htm
danman
danman is offline
post #4 of 19 (permalink) Old 11-27-2002, 06:14 PM Thread Starter
I have a 3.8 t-bird lx
post #5 of 19 (permalink) Old 11-27-2002, 06:49 PM
JustinH's Avatar
you need a trac loc rear end to get two wheel peel.
You have an open diff (one wheel peel)
Justin
JustinH is offline
post #6 of 19 (permalink) Old 11-27-2002, 07:01 PM
Well Posi end or extra 200hp should make both tires spin
KewlBird is offline
post #7 of 19 (permalink) Old 11-27-2002, 10:56 PM
Tim Groth's Avatar
Send a message via AIM to Tim Groth Send a message via Yahoo to Tim Groth
My 90 also only spins one tire for it doesn't have trac-loc but if you want both tires to spin get them damp and then go for it. I got both of them to spin by doing this but it took a while for the other tire to engage.
-Tim
Current Collection
1994 Thunderbird SC - Auto
1994 Thunderbird SC - 5spd
1995 Thunderbird SC - Auto
1997 LX - Auto - Parts Car
Tim Groth is offline
post #8 of 19 (permalink) Old 11-28-2002, 07:39 AM Thread Starter
Justin
Where could i get one of these at? And how much?
post #9 of 19 (permalink) Old 11-28-2002, 08:13 AM
JustinH's Avatar
Do a search for trac loc. Seeing as you have the 7.5'' v6 rear end, you will want to upgrade that to the 8.8'' SC/V8 rear.
A guy by the name of Decy posts on here seldomly, but always has a few that he rebuilds.
"8.8 Traction Lok Pumpkins
IRON CASE
3.27 used takeouts...$150
3.55 used parts (in good condition) freshened up and new seals...$350
3.73 used parts (in good condition) freshened up and new seals...$350
ALUMINUM CASE
3.73 fresh, new FRPP gears, in a low mileage 99 Cobra takeout pumpkin, and new seals...$500
Shipping is extra. E-mail me if interested."
Check out the thread http://forums.tccoa.com/showthread.p...highlight=decy
And send him a email seeing what he thinks.
Justin
JustinH is offline
post #10 of 19 (permalink) Old 11-28-2002, 08:27 AM Thread Starter
So does mine of a track lock? or not?
post #11 of 19 (permalink) Old 11-28-2002, 08:35 AM
JustinH's Avatar
Straight from the tccoa articles. Please read them.
http://www.tccoa.com/articles/gears/gears.html
JustinH is offline
post #12 of 19 (permalink) Old 12-16-2002, 08:12 AM
Careful with the power braking
Most cars today cannot handle the abuse say an old muscle car from the 60's could take. Careful when power braking....13 year old factory parts can get weak......you could snap a motor mount, blow the tranny, snap a u-joint, or even worse do damage to your rear axle. Just my 2 cents......
teebyrd92 is offline
post #13 of 19 (permalink) Old 12-16-2002, 08:56 AM
Send a message via Yahoo to 59bisquik
Hey JustinH....remember there are a few V6 cars out there with a factory 8.8!
94 LX V6, 4 wheel disc, ABS and 8.8
94 3.8 Thunderchicken
59 Chevy Biscayne undergoing frame off rodstoration 383/Hilborn Stack EFI
54 Ford Customline Coupe 351/AOD
59bisquik is offline
post #14 of 19 (permalink) Old 12-16-2002, 11:01 PM
Re: Careful with the power braking
i'd rather break a halfshaft than a tranny any day.... i've busted a half shaft on my 90 3.8 n/a.... and well.. the mechanic had it fixed in literally 30 minutes. i had it towed to his shop, and it was in the street next to the shop (it was sunday and the lot was closed..) he just jacke dit up int he street, changed it, and it was fine. it was only 130 or something final cost parts and labor. however, a tranny woulda costed 1600.... yea... well... u-joints, motor mounts those are bound to go eventually anyways. that reminds.. i need a new right hand motor mount, all the fluid leaked out after 12 years... the left one is solid rubber already so im fine there.. -greg
glowing escape is offline
post #15 of 19 (permalink) Old 12-18-2002, 08:48 PM
ben_cline's Avatar
It seems kinda wierd leaving 1 burnt rubber line. Different tires worked for me. I got new tires and it's better.
ben_cline is offline
post #16 of 19 (permalink) Old 12-18-2002, 08:49 PM
yea.. thats wierd cause kyle (chrometip) got sc rims and new tires and he's been leaving two pretty much all the time. -greg
post #17 of 19 (permalink) Old 12-18-2002, 08:52 PM
ben_cline's Avatar
I had 1 bald tire and 1 that had most of the tread left.
3 different tire types.
post #18 of 19 (permalink) Old 12-18-2002, 08:53 PM
so you're the guy withthe two wheeled mn12! j/k -greg
post #19 of 19 (permalink) Old 12-18-2002, 08:58 PM
ben_cline's Avatar
De-ghettoization? What was ghetto about it? Is that the year with the big grill that comes up into the hood?
