Oil Pump Prime - TCCoA Forums
post #1 of 4 (permalink) Old 12-02-2002, 04:54 PM Thread Starter
Oil Pump Prime
Hi,
I got a quick question, I finally got my car together after chnging my timing chain and I want to go ahead and prime the oil pump. I got a loaner primer tool from autozone to hook up to my drill. The opposite end of the thing looks like a hex socket. The guys over at autozone insist that I need to use the shaft that's attached to the distributor. This poses 2 problems in my mind, how do I take apart the thing? How do I keep it from falling out of the primer tool once I remove the thing from the engine?
-wil
Wil_A_ is offline
post #2 of 4 (permalink) Old 12-02-2002, 07:58 PM
It is stuck in there with a spring around the shaft, if I remember corretly. Just get a rag around the shaft and with some force yank it out, to put it back in, just push. It will probably fall out a fey times, mine did, just have one of those magnetic pick-up tools to fish it out.
Jim
1993 LX 5.0
JSGAuto is offline
post #3 of 4 (permalink) Old 12-03-2002, 09:02 AM Thread Starter
Thanks and another quick question,
I got the shaft on the tool, it came aprt exactly as you said. How long should I run the drill? Is there any concern about building up too much pressure by running it too fast or too long with the engine off?
-wil
Wil_A_ is offline
post #4 of 4 (permalink) Old 12-04-2002, 06:06 AM
I would prime the pump for a good 5 min. You wont hurt the engine. It is better that it is oiled up then not. Remember, you will be "drilling" in the reverse direction.
Jim
1993 LX 5.0
JSGAuto is offline
