Upper and lower control arms? - TCCoA Forums
post #1 of 3 (permalink) Old 09-14-2006, 03:49 PM Thread Starter
Question Upper and lower control arms?
Just wanted opinions on which upper and lower arms might be better: TRW or Moog?
The time has come to change ball joints on my '96 so I figured while I had the car on the lift I'd go ahead and rework the suspension all around before I decide whether or not to lower the car.
I noticed that vogtland springs are a bit cheaper but are not the compound rate like the Eibachs. A bit of insight here would be appreciated from owners of either set as to the pros and cons of either.
Also, will it matter much if I drop the car before or after the planned engine swap? Will the difference in engine mass play MAJOR factors with ride height in the car setup? I know there would be some, but exactly how much (estimated) could be expected?
*edit I just realized that I meant to post this in the general tech forum...sorry guys...
bucket_o_bolts is offline
post #2 of 3 (permalink) Old 09-14-2006, 04:06 PM
It is nice
Either TRW or Moog will be fine.
91CougarLS is offline
post #3 of 3 (permalink) Old 09-25-2006, 03:14 PM
BirdofPrey97's Avatar
They are both the same company.
Honor, Grace, and Dignity.....Do you remember these?
BirdofPrey97 is offline
