Spout connector effects timing - TCCoA Forums
post #1 of 13 (permalink) Old 09-24-2006, 01:13 PM Thread Starter
Make sure you remove the spout connector before setting timing!!! That spout connector is pretty hard to locate on the wiring harness, Its just a little plug taped into the wiring along the left hand side by the plug where you check your codes.
If you change the timing without removing that little plug you might as well be doing nothing at all.
foobarbigtime is offline
post #2 of 13 (permalink) Old 09-24-2006, 03:56 PM
Banned
tada spout connectors to check your timing!! its called needle nose pliers and 5 seconds, and yes dont check your timing without pulling one of those.
Porkchop is offline
post #3 of 13 (permalink) Old 09-25-2006, 08:31 PM Thread Starter
Is there two of those connectors to unplug or just one? I just found one.
post #4 of 13 (permalink) Old 09-25-2006, 08:48 PM
Banned
you only pull one. they are both supposed to be there. i forgot which one to pull but you will figure it out. pull one and if the idle doesnt drop/change then try the other one
Porkchop is offline
post #5 of 13 (permalink) Old 09-26-2006, 02:13 PM
drag-aholic
BAGGED89's Avatar
not on my '89
1989 LX Full Air Suspension
BAGGED89 is offline
post #6 of 13 (permalink) Old 09-26-2006, 08:58 PM Thread Starter
I bet every year had them in different places
post #7 of 13 (permalink) Old 10-24-2006, 10:28 PM
so what if you just left this thing off while you drive?
roger is offline
post #8 of 13 (permalink) Old 10-24-2006, 10:37 PM
If you leave the SPOUT connector off the computer won't advance the timing as you drive. Needless to say, less power, lower mileage, and less money because of the aforementioned.
post #9 of 13 (permalink) Old 10-25-2006, 07:14 PM
dwinthrup's Avatar
my car don't run right with it in i think my timing is off a hair
dwinthrup is offline
post #10 of 13 (permalink) Old 10-26-2006, 11:03 AM
i think my spout connector is behind my passenger shock tower.
1fast'93 is offline
post #11 of 13 (permalink) Old 10-26-2006, 11:06 AM
bad93bird's Avatar
Yall didn't know this allready?
QUADSQUAD MEMBER
bad93bird is offline
post #12 of 13 (permalink) Old 10-26-2006, 02:45 PM
4.3Lcougar's Avatar
I am confused here. my set up looks exactly like the above picture in my 94xr7. what are you talking about removing...spout connector?? is it the that black thing inside the connector.....can someone clarify....im dense!!
1985 THUNDERBIRD CFI 5.0L..
4.3Lcougar is offline
post #13 of 13 (permalink) Old 10-26-2006, 03:37 PM
The SPOUT connector is the gray thing at the end of the plug. All it does is jump the two wires in that connector together.
